em có cây 3220 đang sài tự nhiên m
MCU ID: 0x2142
FLASH ID0: 882E0020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-37\
Checking path: \Products\RH-37\
No ini files found...
Phone Type:
MCU Flash file: D:\PHAI NOKIA\rh37__05.100
Phone Type:
PPM Flash file: D:\PHAI NOKIA\rh37__05.10.image_c
Phone Type:
CNT Flash file: D:\PHAI NOKIA\rh37__05.10c
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: D:\PHAI NOKIA\rh37__05.100
Booting phone...
MCU ID: 0x2142
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x2E882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
Loader size is 0x5538; Loader chk: be
Loader is ready...
MSID: 84849995D9D3F82F9427819CAD
MSID decoded: 9976BAE9001BA453A9000000
FAID: A409B8E6ADD8BBFE03A51C4E
Erasing...
Found 3 interval(s) to erase
Erasing area: 01020000 - 0181FFFF...
Erasing area: 01E60000 - 01FDFFFF...
Operation took 1 minutes 3 seconds...
Writing...
Perm. Data Restore OK
Operation took 4 minutes 51 seconds...
Restarting MCU...
CNT: D:\PHAI NOKIA\rh37__05.10c
Booting phone...
MCU ID: 0x2142
Boot size is 0x09A0
Boot is ready...
Loader size is 0x5538; Loader chk: 5e
Loader is ready...
MSID: 84283919302DF3D7286D07FE10
MSID decoded: 3E4EBAE9001BA453A8000000
FAID: C40E7DA5F6B8B564043437D0
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01820000 - 01A3FFFF...
Writing...
Operation took 0 minutes 56 seconds...
Restarting MCU...
Extracting Content Pack...
Error setting local mode...
CP Extract Failed!
PPM: D:\PHAI NOKIA\rh37__05.10.image_c
Booting phone...
MCU ID: 0x2142
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 84BF3418D4D8FA0937F5872BA1
MSID decoded: 1C15BAE3001BA453AD0005BD
FAID: 747AEA26A896AA166FF73717
Operation took 0 minutes 13 seconds...
Erasing PPM...
Erasing area: 01A40000 - 01E5FFFF...
Operation took 0 minutes 26 seconds...
Writing...
Operation took 1 minutes 17 seconds...
Restarting MCU...
Flashing Done!
Operation took 10 minutes 22 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
ất nguồn, bỏ vô hộp chạy nó báo như vậy nhờ ae xem giúp thank !!!!!
			 3220 mất nguồn cần ae giúp
