    Administrator saigonmobile's Avatar
    Aug 2006
    Tp.Hồ Chí Minh
    Mặc định What is ATF [Advance Turbo Flasher] ?
    ATF [Advance Turbo Flasher] Features:
    Unique Hardware Features:
    480 mbps HIGH-SPEED USB 2.0 Connection ( First In World )
    - PC connection is 40 times faster than any other box in the market
    100% FPGA based implementation of the flash bus protocols( First In World )
    -Significantly faster and more stable than regular MCU based boxes
    Adjustable VCCIO Logic Levels (3.30v, 2.80v and 1.80v)
    -Compatible with old phone model Logic Level (3.30v)
    -Compatible with new phone model Logic Level (2.80v)
    -Compatible with future phone model Logic Level (1.80v)
    Proper ESD protection on the FLASHBUS port
    -Protects phone damage due to Electro Static Discharge
    Ultra Fast Flash Clock currently upto 15 Mhz (First In World )
    -Firmware updatable to support upto 60 Mhz without the need
    of hardware modifications
    Internal VPP Flash Voltage Generator (3.0v, 5.0v, 9.0v and 12.0v)
    -Makes Flash Erasing on slow phones faster
    -Does not require external power adapters to generate 9.0v and 12.0v
    -Uses a Fast Switching SEPIC design
    Hardware Upgradable using internal Expansion Slots
    Micro-SD Card Slot for future developments
    Dual RJ-4x Ports (RJ-45 and RJ-48) for External Communication
    -The RJ-45 Port is the main "Turbo" Bus
    -The RJ-48 Port is the Secondary Bus that can be made
    to support parallel or serial protocols such as 2Mbps UART,
    JTAG, and Flashing Protocols.
    5 Multi Colored LED Indicator Lights
    -Rectangular Orange : FBUS_RX
    -Rectangular Green : FBUS_TX
    -Circular Blue : USB_POWER / ACP-X_POWER
    -Circular Green : VBATT
    -Circular Orange : VPP
    Unique Software Features:
    As the Name Itself says its a powerful tool which can flash all Nokia phones including new protocols via Fbus cable in unbelievable speed and stability in compare of any other 3rd party tool which currently present in market
    - New Protocols Device X3 ,X6 ,E52 ,E55 ,6700 ,etc and all Rapuyama Fbus Flashing (First In World)
    - High Speed Turbo Flashing with Full Speed (First In World)
    Tuning & Maintenance
    - Life Timer Tuning not only reset but you can write your desire life time(First In World)
    - Factory Reset
    - Warranty Edits
    - Production Data Edits
    - Camera Configuration Read/Write
    Imei & locks
    - Unlock Using Code Calculation so no more damages to phone warranty or certificates ( Supports SL1 SL2 & Some So called SL3 )
    - Unlock / Relock Using RPL Method
    - Super Dongle Key Repair
    PM ( Permanent Memory)
    - Read Write Permanent Memory Using SX4 Server
    Phone Test
    - For Self Test Phone Features
    We will update features when we complete more feature on which we are working now.
    More cool things still under development.
    Buy only from ATF (Advance Turbo Flasher) authorized resellers:
    ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
    ATF [Advance Turbo Flasher] official web sites:
    International - Advance Turbo Flasher by AdvanceTeam
    ATF [Advance Turbo Flasher] official support forums:
    World Wide: Advance Turbo Flasher - GSM-Forum
    Indonesia: ATF (Advance Turbo Flasher))
    Philippine: Gsmph
    Syria: Arabic Support (Syria) GsmVIP
    Chinese support forum : ATF Box
    Vietnam: Saigonmobile
    !!! Feel The Power Of Turbo Flashing Speed !!!
    CTY TNHH VIỄN THÔNG HOÀNG THÔNG
    ĐT/FAX :028.3.9572152 - 028.3.8575707 - 0283.9574129
    V.I.P jerrylevu's Avatar
    Jun 2005
    sài gòn
    Cục này bây giờ giá khoảng bao nhiêu vậy admin ?
    Aug 2006
    Tp.Hồ Chí Minh
    Giá hiện tại : 2.990.000 VND
    V.I.P nhatkha's Avatar
    Feb 2006
    Trung Tâm Kha Oanh .
    Nó chạy bb5 đời mới nhanh như gió .
    Thành viên tích cực v&tmobile's Avatar
    Ctythegioididong
    đã test mới mua tai HT hum nọ chạy cũng bình thường , được cái làm mấ Cái WD2,BB5 thì tuyệt !
  1. các anh ơi cho mình xin bok setup của hộp Advance Turbo Flasher
    By quangngocbk in forum Advance Turbo Flasher
    Bài viết cuối: 21-06-2012, 22:35
  2. Advance Turbo Flasher v8.00
    By saigonmobile in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 26-11-2011, 10:33
  3. ATF [Advance Turbo Flasher] version 5.10 Update
    By hungphongmobile™ in forum Advance Turbo Flasher
    Bài viết cuối: 07-05-2010, 23:53
  4. ATF (Advance Turbo Flasher) Beta v4.1 06-03-10
    By jerrylevu in forum Advance Turbo Flasher
    Bài viết cuối: 06-03-2010, 14:56
  5. Trả lời: 0
    Bài viết cuối: 17-02-2010, 15:54
