Em nhận em này bị rơi nước. vệ sinh thì lên contact. đưa vô Jaf info được thế này mong các bác giúp đỡ a.
đây là log Info
Powering the phone...
Reading...
MCU SW version: V 07.21
05-11-08
RM-237
(c) Nokia.
HW version: 5008
PCI version:
RFIC version: 17211721
DSP version:
ICPR61_08w10
PPM version: V 07.21
05-11-08
RM-237
(c) Nokia.
V
BT MCM version: 06cc-P9.1
Retu version: 32
Tahvo version: 53
Production serial number: MKO292886
Product code: 0514949
Module code: 0203291
Basic production code: 0542523
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 12345610654321?
IMEI spare to net: 1A 32 54 16 60 45 23 01
IMEI SV to net: 13 32 54 16 60 45 23 21 F5
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-237.ini
Setting local mode...
Reading product code...
Product Code: 0514949
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
Checking path: \Products\RM-237\
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Done!
Changing mode...Done!
Switching to serial...
Reading...
05-11-08
RM-237
(c) Nokia.
HW version: 5008
PCI version:
DSP version:
ICPR61_08w10
05-11-08
RM-237
(c) Nokia.
V
Retu version: 32
Tahvo version: 53
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
LOCK STATUS:
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
 DTDD :0922972486
yahoo nguyenquang_201086
