    Thành viên chính thức ahuytelephone's Avatar
    Mặc định 1680c-2b cần giúp
    1680c-2b hàng tmobile, em chạy về rm-394 sau đo wr pm, ok hết, nhưng khi unlock thì báo lỗi sau đó mất nguônl luôn, em unlock bằng jaf. cần giúp của các pro.
    ĐÔ LƯƠNG _ NGHỆ AN
    vứt cái log lên anh em xem cho
    Getting MCU ID
    MCU ID: 0x3162
    FLASH ID0: 317E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    First 16 bytes: AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 06.82
    26-09-08
    RM-394
    (c) Nokia
    HW version: 1000
    PCI version:
    UEM version: 1328
    UPP version: 12642
    RFIC version: 0500
    DSP version: ICPR62_08w27_U
    LCD version: SUEZ
    PPM version: V 06.82
    26-09-08
    RM-394
    (c) Nokia
    V
    Content Pack version: Content: v
    V 06.82
    26-09-08
    RM-394
    (c) Nokia
    Production serial number: HAB170238
    Product code: 0560306
    Module code: 0203777
    Basic production code: 0556746
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 011751000023536
    IMEI spare to net: 0A 11 57 01 00 20 53 03
    IMEI SV to net: 03 11 57 01 00 20 53 43 F5
    Master Code: 4633104615
    Phone type: RM-394, Software version: 06.82, Language Pack: V
    User code: 12345
    Block 1:
    Lock 1: CLOSED -> Lock Data: 310160
    Block 2:
    Lock 1: CLOSED -> Lock Data: 310200
    Block 3:
    Lock 1: CLOSED -> Lock Data: 310210
    Block 4:
    Lock 1: CLOSED -> Lock Data: 310220
    Block 5:
    Lock 1: CLOSED -> Lock Data: 310230
    Block 6:
    Lock 1: CLOSED -> Lock Data: 310240
    Block 7:
    Lock 1: CLOSED -> Lock Data: 310250
    Block 8:
    Lock 1: CLOSED -> Lock Data: 310260
    Block 9:
    Lock 1: CLOSED -> Lock Data: 310270
    Block 10:
    Lock 1: CLOSED -> Lock Data: 310310
    Block 11:
    Lock 1: CLOSED -> Lock Data: 310580
    Block 12:
    Lock 1: CLOSED -> Lock Data: 310660
    Block 13:
    Lock 1: CLOSED -> Lock Data: 310800
    Block 14:
    Lock 1: CLOSED -> Lock Data: 310490
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-394.ini
    Setting local mode...
    Reading product code...
    Product Code: 0560306
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-394\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-394\
    No ini files found...
    Done!
    Unlocking...
    IMEI: 011751000023536
    ASIC: b
    SW version: 06.82
    Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rm-394\rm394__06.82.mcusw
    Decrypting flash...Done
    Checking ROM call...Done
    Checking security function...Done
    Encrypting....Done
    Patch status: 00
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    FLASH ID1: 317E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11
    Flash ID is 0x7E310100
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x7528; Loader chk: a2
    Loader is ready...
    MSID: 848FED90F66585BE6A109D87F3
    MSID decoded: 2C40BAE9000FFE74AA000000
    FAID: 814DAFD0D0DC8F657DA9E955
    Erasing area: 01080000 - 0109FFFF...
    Perm. Data Restore OK
    Failed! Aborting!
    các pro giúp zum với, khách hối quá
    flash lại thì lên nguồn tiếp, unlock thì lại mất nguồn tiếp. các pro xem zum tí.
    đây là cái log flash lại:
    Getting MCU ID
    MCU ID: 0x3162
    Algo is ready...
    Done!
    Phone Restarted...
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-394\rm394__06.82.mcusw
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-394\rm394__06.82.ppm_v
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-394\rm394__06.82.image_v
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rm-394\rm394__06.82.mcusw
    Booting phone...
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing...
    Found 2 interval(s) to erase
    Erasing area: 01020000 - 01C3FFFF...
    Operation took 1 minutes 4 seconds...
    Writing...
    Operation took 4 minutes 31 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rm-394\rm394__06.82.image_v
    Booting phone...
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    File is already converted to 128k page...
    Loader is ready...
    MSID: 8469BCEB386CACF0D7BE9A155E
    MSID decoded: D26EBAF1000FFE74AA000610
    FAID: 8D10E9F728F1AE6E0B8C9C2C
    Erasing Content Pack...
    Erasing area: 02000000 - 02DBFFFF...
    Erasing area: 02DC0000 - 02F9FFFF...
    Operation took 2 minutes 52 seconds...
    Writing...
    Operation took 1 minutes 49 seconds...
    Restarting MCU...
    Extracting Content Pack...
    Running: (c) Nokia File Server
    CNT Extract OK.
    PPM: C:\Program Files\Nokia\Phoenix\Products\rm-394\rm394__06.82.ppm_v
    Booting phone...
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 8476B79B70F67EA8C9F4BFC2DD
    MSID decoded: 3E4EBAE9000FFE74AA000000
    FAID: 7D01A0E8549072B0C58D46F6
    Erasing PPM...
    Found 1 interval(s) to erase
    Erasing area: 01C40000 - 01FFFFFF...
    Operation took 0 minutes 20 seconds...
    Writing...
    Operation took 1 minutes 29 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 13 minutes 6 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Resetting PPC...
    Done!
    Thành viên chính thức thaonhu1973's Avatar
    Sep 2007
    hạ nó v 5.61 ok liền bạn ơi 100%
  7. ( thaonhu1973 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ahuytelephone (24-03-2010)
    de em thu xem
  1. Trả lời: 3
    Bài viết cuối: 02-02-2010, 11:40
  2. 1680c cần giúp
    By khanhmobilehang in forum DCT4 - WD2
    Bài viết cuối: 27-09-2009, 07:04
  3. 1680c cần giúp
    By thenghiep in forum DCT4 - WD2
    Bài viết cuối: 20-05-2009, 18:14
