    Thành viên mới huynhviet's Avatar
    Jan 2010
    Mặc định Nhờ máy anh xem giúp cái log 1208
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
    Checking path: \Products\RH-105\
    No ini files found...
    Phone Type:
    MCU Flash file: C:\Program Files\nokia\Phoenix\Products\1208_RH_105_V_05.06\r h105_05.060
    Phone Type:
    PPM Flash file: C:\Program Files\nokia\Phoenix\Products\1208_RH_105_V_05.06\r h105_05.06mr
    Phone Type:
    CNT Flash file: C:\Program Files\nokia\Phoenix\Products\1208_RH_105_V_05.06\r h1050_nai5.06mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\nokia\Phoenix\Products\1208_RH_105_V_05.06\r h105_05.060
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: d9
    Loader is ready...
    MSID: 849CCFD3BEF2A8439035A6E446
    MSID decoded: 3E4EBAE900140014A9000000
    FAID: 9C324E1CBFA3020F88AFC4F9
    Erasing...
    Found 5 interval(s) to erase
    Operation took 0 minutes 36 seconds...
    Writing...
    Error cmd: 14!
    Addr: 0108C000
    bi gì vậy mấy anh???
    Thành viên kỳ cựu THANH TRUNG's Avatar
    Kiên Giang
    coi lại cpu và flash
    Thành viên tích cực luy717's Avatar
    cmd14. đa số các loại máy sài cpu .id 2292 đều bị lỗi cmd14 ....và phải thay cpu
    Super Moderator tuanhoang's Avatar
    Sep 2007
    chỉ là CPU ,đừng sờ vào flash chi cho mệt !
    TRUNG TÂM SỬA CHỮA DTDD TUẤN HOÀNG - GIA TÂN 1-THỐNG-NHẤT-ĐỒNG NAI-QL-20
    Chuyên SW & HW all Mobile -LH_ ĐT:0613778888-3867722-0902442220-0966907790
    Bank-plus Cua VT:9990110214707_Vũ Tiến Hoàng : NH Agribank số TK:5915205023902
    Thành viên tích cực taimobile_1988's Avatar
    Jan 2010
    Thanh Hóa city
    ban chạy bằng hộp j vậy ,thử chạy hộp khác xem ,thay cáp khác chay xem thế nào rôi tính phần cứng sau bạn
    Thành viên chính thức manhhai_au's Avatar
    Trích Được post bởi taimobile_1988 Xem bài viết
    Bạn nhìn log chạy chưa mà hỏi ng ta chạy =ji?báo lỗi vậy thì sờ đến upp thôi nhé khỏi làm gì khác cho mệt
    Học hành là việc lớn.Yêu đương là việc nhỏ.Việc nhỏ không làm được sao làm được việc lớn
    Thành viên tích cực v&tmobile's Avatar
    Ctythegioididong
    CPU nhé , thay nó đi rồi Flash lại , con Flash cứ để nguyên đó .
    Thành viên tích cực hoanglinhmobiphone's Avatar
    thay cpu trước đi anh .rồi nạp trương trình lại nó là ok
  1. Giúp em mở mạng 1208 với
    By lippo1111 in forum DCT4 - WD2
    Bài viết cuối: 17-12-2011, 22:12
  2. 1208 cần giúp
    By tuongphuocmobile in forum DCT4 - WD2
    Bài viết cuối: 19-10-2011, 08:44
  3. các anh em giúp mình cây 1208 phím không ăn.
    By quocvienlxag in forum DCT4 - WD2
    Trả lời: 16
    Bài viết cuối: 16-06-2010, 16:15
  4. 1208 cầm giúp!
    By laothanh in forum BB5
    Bài viết cuối: 07-10-2008, 16:19
  5. ặc ặc 1208 bệnh lạ , cần giúp ,,
    By hoangkien822003 in forum DCT4 - WD2
    Bài viết cuối: 12-07-2008, 17:43
