    Thành viên tích cực phuc_gsm07's Avatar
    Mặc định Mx_key xin giúp
    Em mới mua cái Mxkey cài ra lấy máy chạy thử chạy con nào cũng chết không lên nguồn, cùng ver đấy mang sang hwk hay jaf chạy lại thì lên bình thường.
    Đây là log của con 6085 các bác xem dùm em với. ( Em ko chọn file tự động mà chọn 3 file bung sẵn )
    Hôm qua cài ra mới repair con 6300 nghe nhạc mất nguồn thì vẫn ok
    Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010)
    Processing file: rm198__06.00.mcusw.bin as MCU
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported RAP Ids: 0103192101001101, 010C192101001101
    RAP Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 06C00113F83A6D56B761294118F2D8464F023088
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    FlashID0: 0001 002F - 0000 6921 [AMD S29NS256N,256 Mbits] type: NOR,RAP
    TransmissionMode: 16Bit
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    RAP PAPUBKEYS HASH: C44614CCC0A09C4A52B890FA55B4B31AF4787668
    Erase size: 16.94 MB
    CMT NOR area [00000000-000DFFFF] erased in 2.703 s
    CMT NOR area [00100000-0110FFFF] erased in 1 min 8.015 s
    Flash programming ...
    CMT PAPUBKEYS: C44614CCC0A09C4A52B890FA55B4B31AF4787668 (RAP Certificate 47 v1) written.
    Programming completed in 1 min 42.657 s
    Processing file: rm198__06.00.ppm_v as PPM
    [BB5,BB5 ALGORITHM] size: 4.42 MB
    RAP Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 4.75 MB
    CMT NOR area [01120000-015DFFFF] erased in 22.000 s
    Programming completed in 31.094 s
    Processing file: rm198__06.00.image_vg_is_128 as CNT
    [BB5,BB5 ALGORITHM] page size: 128 K size: 4.38 MB
    RAP Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 10.00 MB
    CMT NOR area [015E0000-01FDFFFF] erased in 22.828 s
    UCP page size is 128 K.
    Programming completed in 37.078 s
    Flashing completed in 5 min 52.250 s
    Không biết còn cài đặt chỗ nào sai hay cách chạy còn thiếu sót gì xin các bác hưỡng dẫn. Thank
    Y!M: Votinh_votinh_02@yahoo.com
    ĐT : 0916.031.444 - 0303.644.616
    Có vip nào giúp em với
    Thành viên mới duy bang's Avatar
    Dec 2009
    Trích Được post bởi phuc_gsm07 Xem bài viết
    bo usf3 di ban chay cong com la ok
    Thành viên chính thức maingoc186's Avatar
    haiduong city
    chạy xong chưa đồng bộ á
    GOODLUCK
    0987219892
    Trích Được post bởi maingoc186 Xem bài viết
    Chạy xong nó không cho đồng bộ
    Trích Được post bởi duy bang Xem bài viết
    Chạy cổng com là sao hả anh trai.
    V.I.P Chaunv.Mobile's Avatar
    Tiền Giang
    nói chung là Mxkey flash rất cùi mía, nhưng bù lại những phần khác thì ok
    Học Học Nữa Học Mãi
    chaunv78@yahoo.com 0945.618.618
    Thành viên tích cực v&tmobile's Avatar
    Ctythegioididong
    cvon này điểm mạnh của nó chỉ là SX4, Unlock của nó là chính Flash thì dở mà chậm
  1. xin giúp cài đặt mx_key
    By quyenhquang in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 12-07-2011, 22:35
  2. mx_key Cần Giúp
    By ndlong11 in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 11-04-2011, 17:34
  3. mx_key Cần Giúp
    By hoainam_mobi in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 09-04-2011, 16:14
  4. các ae có rảnh vì vào xem giúp e xem cái mx_key của e cái và cho e hướng dẫn với
    By viethuy_mobi in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 04-03-2011, 09:41
  5. Mx_key xin giúp
    By phuc_gsm07 in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 04-04-2010, 10:19
