mới nhận một 1661-2b rh-121 hàng tmobile, không biết con này chơi bằng jaf được không? xin các pro cho ý kiến
 giải pháp unclok 1661-2b rh-121 bang jaf
				em này phải đưa qua hwk mà đập bạn ui
				1661 id 2293 hiện tại chưa có thiết bị nào ullock được dòng ID này
				Getting MCU ID
MCU ID: 0x2293
FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Reading...
MCU SW version: V 03.00
02-09-09
RH-121
(c) Nokia
HW version: 3000
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_09w03_UPP
LCD version: WIN:BOHAIv91
NT39121
PPM version: V 03.00
02-09-09
RH-121
(c) Nokia
UB
ADSP SW version: V 03.00\n02-09-09\nRH-121\n(c) NMP\nub_na
Production serial number: HME268529
Product code: 0580796
Module code: 0204020
Basic production code: 0577060
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 011886006508112
IMEI spare to net: 0A 11 88 06 60 05 18 01
IMEI SV to net: 03 11 88 06 60 05 18 11 F2
Master Code: 5255375577
Phone type: RH-121, Software version: 03.00, Language Pack: UB
User code: ÿ#
Block 1:
Lock 1: CLOSED -> Lock Data: 310160
Block 2:
Lock 1: CLOSED -> Lock Data: 310200
Block 3:
Lock 1: CLOSED -> Lock Data: 310210
Block 4:
Lock 1: CLOSED -> Lock Data: 310220
Block 5:
Lock 1: CLOSED -> Lock Data: 310230
Block 6:
Lock 1: CLOSED -> Lock Data: 310240
Block 7:
Lock 1: CLOSED -> Lock Data: 310250
Block 8:
Lock 1: CLOSED -> Lock Data: 310260
Block 9:
Lock 1: CLOSED -> Lock Data: 310270
Block 10:
Lock 1: CLOSED -> Lock Data: 310310
Block 11:
Lock 1: CLOSED -> Lock Data: 310580
Block 12:
Lock 1: CLOSED -> Lock Data: 310660
Block 13:
Lock 1: CLOSED -> Lock Data: 310800
Block 14:
Lock 1: CLOSED -> Lock Data: 310490
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-121.ini
Setting local mode...
Reading product code...
Product Code: 0580796
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-121\
Checking path: \Products\RH-121\
No ini files found...
Done!
ìno ra như thế đó, có chơi bằng jaf được không các pro
				máy đang luck, mà con upp này MCU ID: 0x2293 thì thua bạn,Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Block 8:
Block 9:
Block 10:
Block 11:
Block 12:
Block 13:
Block 14:
				thay cpu di rồi unlock , nhungn7 bảo khách trước nha bạn
				con này thay upp 1200 nạp 1661-2 ,write pm 1661-2 , dùng mkey unlock sau đó câu lọc là ok
YM: thang_gsm
				cpu 2293 là thay đi . nạp làm chi có được đâu
