1202 im ??????????????????
máy mới vừa bán ra cho khach thì bật nguồn lên 1 phut tắt nguồn ấn *#06# thì im ??????????????????? em đã dùng mxkey online logger mà vẫn không đuợc mong anh em giúp đỡ đay là log online logger cửa nó
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00EE8746A3BDA66
ASIC type: 11
UEM Imei: 35173006113368
Connecting to server ...OK, Login ...
Hello C0803B7F, you have 970 credits left.
RPL saved to "C:\mobileEx\3.3\data\backup\RPL\3517300611336 8.RP L"
Programming FLASH Imei ...
FLASH programmed successfully.
Phone Type: RH-112
SW Version: V 04.03 29-06-09 RH-112 (c) Nokia
Imei plain: ??????????????-?
Product Code: 0562324
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: MR
Language Pack:
- not available.
Imei plain is invalid !!!
Imei net: 00000000000000
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000030000
SIMLOCK_DATA corrupted!
