em mới mua mx cài đặt ok
mà chạy toàn báo lổi
anh em xem dùm em cái log
và chỉ cho e cách khắc phục.
coi bị lổi mx key hay jaf để em còn đi đổi
lúc đầu jaf e xài 1.98.62 xài crack rất ok sau khi mua mx key em nâng lên
mx bản 1.7 jaf 1.98.66
chạy ko dc.qua pkey crack cũng ko dc chạy xong nó bôt lại ko dc =>mất nguồn.
mong mấy anh chỉ cái hư
thanks
Version from phone: 07.20
Version from file: 07.20
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 2BB00015B9E76B5667F97C478FA33A50B45842DB
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP
ExtDEVC: FFFF 0000 - 0000 0000
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 7C1A1F5C3DB717937F54455937AF9DA76AA2EE13
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35555001874252
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35555001874252_BA CK.rpl"
Processing file: rm146__07.20.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.56 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Storing certificate ...OK
Total erase size: 16.37 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00020000-0007FFFF]
CMT NOR area [00080000-000DFFFF]
CMT NOR area [00100000-001FFFFF]
CMT NOR area [00200000-0031FFFF]
CMT NOR area [00320000-0105FFFF]
CMT NOR area [01060000-01067FFF]
CMT NOR area [01068000-0107FFFF]
erased in 40.672 s
Flash programming ...
Error chk C7012D0103CD
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00020000, Result: 0000
Please try to use newer flashloader.
Flashing terminated with error(s) in 3 min 15.391 s
RX Buffer: C7012D0103CD00
