Kết quả 1 tới 2 của 2
    Product Manager Hoang Thong Mobile's Avatar
    Dec 2006
    Mặc định .::Unlock E250v for UFS::.
    How to unlock E250v using UFS
    Connect youre UFS TWISTER BOX
    press connect
    after youre box is connecting press OM/swift and take model E250
    connect cable (D800)
    connect Mobile phone (E250) with battery inside (take fully charged battery always better)
    on the screen will be battery charging
    do not turn on !!!!
    and press in the menu UNLOCK 2 EP
    UFS is now booting swift (i using baudrate 115200)
    this takes a few minutes (4 minutes) (take a break, get some coffee )
    in youre box you will see
    Preloader Ok, 115200 Baud
    Flashloader Ok
    FLASH Id: 00EC2206000100010014, Samsung KAP29VG00M
    then you get in youre box this
    MCU Read Done, 2359296 byte(s), Time: 3:55, 0
    E2P Info:
    IMEI: x5x4x3-01-x07xx3-7
    SIMLOCK STATUS: 01
    MCC-MNC: 000-000
    #SIMLOCK*NET*45xxxx60#
    then you must save this (save in read)
    and then the UFS box will asked you
    ARE YOU SURE TO REMOVE SIMLOCK FLAGS !!!!
    PRESS YES
    then the box will say Writing MCU flash memory
    and after this you will see on youre screen
    C:\Program Files\SarasSoft\UFS\UFS_SAMs\Read\E250_353463-01-207324-6_E2P.bin
    File CRC: 0xFCACA381
    MCU Write Done, 786432 byte(s), Time: 1:11
    and now is Phone Unlocked...
    CTY TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    ĐT/FAX : 083.9572152 - 08.38575707 - 0903.303.717
    Skype : saigonmobile
    YM : saigonmobile_vn
    MSN : saigonmobile@hotmail.com
    Thành viên mới foreverlovetn's Avatar
    Mar 2006
    356 Trần Phú - Thường Tín
    Thanks , Hthongvn !
  1. Infinity BEST v1.72 , Lumia WP7x : Direct Unlock, BL Unlock, User Data Recovery
    Bài viết cuối: 27-09-2013, 10:24
  2. xin file full tv của E250v
    By dungxi in forum Phần mềm Samsung
    Bài viết cuối: 18-01-2009, 16:33
  3. E250V unlook
    By phuocloi_mobile in forum Agere System
    Bài viết cuối: 18-01-2009, 14:24
  4. E250v unlock xong sóng mất sóng
    By quang3g in forum Phần mềm Samsung
    Bài viết cuối: 08-07-2008, 13:02
  5. Box Update ! New Samsung phones Added : E250v D900i C180
    By hungphongmobile™ in forum Các thiết bị khác
    Bài viết cuối: 20-06-2008, 12:08
