How to unlock from network DB2020/DB2012/PNX5230 phone using "special unlock account" ?
A:
first, download latest version, special server support started from 063.
select USB as interface. that is REQUIRED.
select phone model
settings - check "use server for csca unlock/flash", "do full unlock instead of usercode reset", fill your login details.
back to semc tab, press unlock, attach phone with pressed "C" buttons.
wait for signature calculation, it can take about 5 minutes.
if calculation will fail, your credits will NOT be deducted.
if calculation is success, then signature will be saved in backup\%imei% folder in your setool2 directory.
next, backup will be created so you will be able to restore phone if something will go wrong (hardly believe, but who knows...)
next, you will be prompted to detach phone and turn it on.
do so.
detach phone.
turn it on FULLY
phone will be on 5 locks, that is normal.
connect phone to usb.
if phone will ask you switch to phone mode - switch to phone mode.
it can ask you for drivers,if you not installed them previously.
install all needed phone drivers (phones.rar on support area)
be SURE that you install all drivers correctly.
press "testpoint ok"
note: in latest setool2 version phone will be searched constantly on all
available comports until it will be found. So, you not need to press "TESTPOINT OK"
procedure will continue,phone will be switched off and unlocked.
remember, if something will go wrong - you have a backup of security units.
cost of DB2020 unlock is 10 credits. it divided into 3 steps: signature calculation 5 credits (charged once), phone prepare - 1 credits (normally charged once, in case of errors on step2 - charged again, credit NOT refunded), phone unlock - 4 credits (charged once, if by accident, server is recharging while you executing unlock, credits NOT charged and 1 credit returned automatically, so you not loosing anything)
as usual, credits will NOT be recovered in case of connection failures. (error 10054,10060). that is NOT terms for discussion.
NOTE! there is STILL REMAIN SERVER-BASED USERCODE RESET FOR DB2020/DB2012/PNX5230.
it will work, if you UNCHECK option "do full unlock instead of usercode reset" and press UNLOCK.
note: i STRONGLY recommend you to instal PHONE drivers BEFORE starting unlock procedure. Otherwise, you CAN (very unlikely, but EVERYTHING possible in that world) get error on step2 (phone search) and will lose 1 credit.
			 Anh em nào giỏi Eng xin vui lòng dịch dùm
