tình trạng máy là kẹp nguồn vào dòng báo lên 0.2A bật nguồn lên rồi tắt luôn cho vào box check thì nó báo như này anh em coi hộ nha.
Getting MCU ID
MCU ID: 0x1052
FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 003500EC <=> SAMSUNG (SEC) -> K5E5657ACB Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 03.62
04-Nov-05
RM-72
GSM P1.1
(c) NMP.
HW version: 5010
PCI version:
UEM version: 400
UPP version: 4178
RFIC version: p
10ff11ff0205
DSP version: p
B0446T_05w14
LCD version: SHARP
PPM version: V 03.62
04-Nov-05
RM72_73_-
GSM P1.
V
ADSP SW version: TIKU_PB_04w47_05_w40
Production serial number: 2FH917466
Product code: 0524570
Module code: 0202552
Basic production code: 0519797
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 352285014139779
IMEI spare to net: 3A 25 82 05 41 31 79 07
IMEI SV to net: 33 25 82 05 41 31 79 17 F7
Master Code: 2272757532
Phone type: RM-72, Software version: 03.62, Language Pack: V
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-72.ini
Setting local mode...
Reading product code...
Product Code: 0524570
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-72\
Checking path: \Products\RM-72\
No ini files found...
Done!
			 6230i cần giúp!!!
 6230i cần giúp!!!
