máy đả có dấu hiệu wa thay thợ rồi ! upp , flash đả đổ keo !bấm nguồn kim dòng nhích đến số 1 rồi tụt ! ae cho ý kiến nha ! thanks .......? MCU ID: 0x1201
FLASH ID0: 8C9E0420 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
First 16 bytes: A9 00 B2 1A 00 01 0B 05 E9 18 E2 A4 F1 8E 59 14
Checking RAM for ALGO...
Can't find flash loader for this phone...Aborting!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Setting local mode...
Failed! Aborting!
Failed! Aborting!
Failed! Aborting!
Failed! Aborting!
Checking path: E:\bkey jaf\JAF-20PKEY\RM-5\
Checking path: \Products\RM-5\
No ini files found...
Phone Type:
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-5\rm5_08.110
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-5\rm5_08.11qd
Languages in ppm: English,Chinese Trad.
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\rm-5\rm5_08.110
Booting phone...
MCU ID: 0x1201
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x9E8C2004
Cannot find flash loader for this phone...Aborting!
Error Loading loader!
KHÔNG THAY ĐỔI THÌ CHẤP NHẬN
KHI LÌA TRẦN CÓ MẤY NGƯỜI ĐƯA
