Kết quả 1 tới 10 của 17
    Thành viên mới baolam_1988's Avatar
    Mặc định xin giúp 2700 chay tieng viêt bi contact sẻvice
    MCU SW : V 09.95 02-04-10 RM-561 (c) Nokia
    PPM SW : V 09.95 02-04-10 RM-561 (c) Nokia V
    Prd.Code: 0579808
    Bpr.Code: 0577212
    Prod.Sn : DAR009649
    HW Vers : 1000
    EM VILMA: 16
    EM BETTY: 22
    RFIC Ver: 06540601
    DSP Vers: ICPR72_09w26
    LCD Type: SEIKO
    IMEI : 358283-03-839014-2
    SL Serv : SIMLOCK SERVER
    SL Conf : 000-00-00000000000
    SL Prof : 0141194A00000000
    SL Count: 00 00
    SL Data Corrupted
    Provider: Not Found
    mong ae giúp đõ
    JAF version 1.98.62
    Detected PKEY: 9000BC25
    Card life counter: 99.99%
    Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
    USB Cable Driver version: 7.1.27.0
    Changing mode...Done!
    Booting phone...
    FAST PHONE detected!
    CMT Boot Data:
    Asic ID: 000000010000022600010006030C192101033000
    Asic Mode ID: 00
    Asic EM ID: 00000B22
    Asic Public ID: 1C1001103B368C56B6CCC7C5002B07BB2B6D4086
    HASH: 9DDBFCFE6E73CED7D8C6268C8EB8572300000000
    ROM ID: 273F6D55DFAAF68F
    Error finding cmt boot file...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 09.95
    02-04-10
    RM-561
    (c) Nokia
    HW version: 1000
    PCI version:
    RFIC version:  06540601
    DSP version:
    ICPR72_09w26
    LCD version: SEIKO
    PPM version: V 09.95
    02-04-10
    RM-561
    (c) Nokia
    V
    BT MCM version: 2222-302
    Retu version: 16
    Tahvo version: 22
    Content Pack version: Content: v_grey
    V 09.95
    02-04-10
    RM-561
    (c) Nokia
    Production serial number: DAR009649
    Product code: 0579808
    Module code: 0204245
    Basic production code: 0577212
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 358283038390142
    IMEI spare to net: 3A 85 82 03 83 93 10 04
    IMEI SV to net: 33 85 82 03 83 93 10 54 F2
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 0000000000000000
    Provider: Unknown provider
    Key Code count: 0, FBUS Code count: 0
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-561.ini
    Setting local mode...
    Reading product code...
    Product Code: 0579808
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-561\
    Checking path: \Products\RM-561\
    No ini files found...
    Done!
    Setting test mode...
    Setting FULL FACTORY...
    Done!
    Resetting SERVICE CENTER...
    Done!
    Resetting USER DATA...
    Done!
    Reading...
    02-04-10
    RM-561
    (c) Nokia
    HW version: 1000
    PCI version:
    DSP version:
    ICPR72_09w26
    LCD version: SEIKO
    02-04-10
    RM-561
    (c) Nokia
    V
    Retu version: 16
    Tahvo version: 22
    V 09.95
    02-04-10
    RM-561
    (c) Nokia
    Flash code:
    Order number:
    ATO:
    Default SN type:
    LOCK STATUS:
    Done!
    Reading...
    02-04-10
    RM-561
    (c) Nokia
    HW version: 1000
    PCI version:
    DSP version:
    ICPR72_09w26
    LCD version: SEIKO
    02-04-10
    RM-561
    (c) Nokia
    V
    Retu version: 16
    Tahvo version: 22
    V 09.95
    02-04-10
    RM-561
    (c) Nokia
    Flash code:
    Order number:
    ATO:
    Default SN type:
    LOCK STATUS:
    Done!
    cúu e vói khách dử quá............................
    Thành viên mới lang_tu84tb's Avatar
    bạn mang qua mx-key boot rồi quăng cái log lên xem thế nào nhé
    Vi phạm nội quy dinh11's Avatar
    cái nè mx key làm ok.uplade Splock=>Repair SD=>write 1&309=>Full Factory=ok
    Thành viên chính thức thuongvinhtp's Avatar
    Aug 2006
    có backup trc khi nạp kg bạn. nếu có thì nạp vô lại thôi. 2700 là sl3 mà mxkey cũng ngồi ngó thôi chứ làm đc gì...
    bình phước
    banh rồi
    V.I.P UNLOCKDTDD's Avatar
    Trích Được post bởi nokia825 Xem bài viết
    banh rồi
    nếu back lại thì mong cưu được mà bác hy vong chũ thớt cứu được
    bình phước
    Trích Được post bởi QUYNHCHAU 02 Xem bài viết
    tui cũng hi vọng như vậy, biết nói gi chúc chủ thớt thành công.
    Thành viên kỳ cựu thanhcong mobile's Avatar
    sl3 có backup thì còn có cơ hội trả về,ko thì po tay thay cả cặp thôi
    Dec 2007
    Thanhba-Phúthọ
    dinh11(cái nè mx key làm ok.uplade Splock=>Repair SD=>write 1&309=>Full Factory=ok )
    mới support hả pro ơi?....Tui đang có mấy con 2700&5130 đang CS đây nè (mua có 300k/cây) mà chưa làm được
    GONE WITH THE WIND
  1. c2-00 contact sẻvice cần giúp
    By kjssboy in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 09-07-2012, 10:16
  2. 1208 bị contact sẻvice mong anh em giúp
    By tienthe083 in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 08-04-2011, 16:12
  3. cần giúp gấp 1650 hiển thị contact sỉvice
    By tuyen_mobile1709 in forum DCT4 - WD2
    Bài viết cuối: 15-07-2010, 07:11
  4. 1110i contact sẻvice giúp em với
    By hongchung2 in forum DCT4 - WD2
    Bài viết cuối: 26-12-2008, 14:42
  5. 6610i contact sẻvice cần giúp!
    By nmrhoang in forum DCT4 - WD2
    Bài viết cuối: 29-11-2008, 22:59
