    V.I.P ThanhHai_GSM's Avatar
    Mặc định log 6500c nghe nhac mất nguồn
    log check bàng MXkey
    RAP Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
    EM0 ID: 00000295
    EM1 ID: 00000B22
    PUBLIC ID: 14F0010A88B4025414ABBE88A07AF03196B6A009
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP
    TransmissionMode: 16Bit
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    RAP PAPUBKEYS HASH: D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88
    Original Imei: 35768301583960
    Original Product code: 0551671
    Bluetooth ID: 001CD6E47D58
    Phone Type: RM-265 (Nokia 6500c)
    SW Version: V 06.61 26-03-08 RM-265 (c) Nokia
    Imei plain: 35768301583960-0
    Product Code: 0551671
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    "C:\Program Files\Nokia\Phoenix\Products\RM-265" folder created.
    Imei net: 357683015839600
    Version: SIMLOCK SERVER
    Provider: Nokia Test, Country: Finland
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    PROFILE_BITS: 8000000000000006
    BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    mình chạy lại báo lỗi vậy nhờ anh em xem giúp
    Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
    Processing file: rm265__09.45.mcusw as MCU
    [BB5,BB5 ALGORITHM] size: 18.13 MB
    Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000
    RAP Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 21.12 MB
    CMT NOR area [00000000-0001FFFF] erased in 0.406 s
    CMT NOR area [00040000-000BFFFF] erased in 1.156 s
    CMT NOR area [000C0000-0013FFFF] erased in 0.234 s
    CMT NOR area [013C0000-0153FFFF] erased in 0.453 s
    CMT NOR area [00140000-013BFFFF] erased in 4.344 s
    Flash programming ...
    CMT PAPUBKEYS: D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88 (RAP Certificate 87 v1) written.
    Error while programming [00] at 0x000A0400, Result: 0000
    Please try to use newer flashloader.
    Flashing terminated with error(s) in 44.593 s
    RX Buffer: B372
    Thành viên tích cực nguyentienthanh_dt's Avatar
    nó báo lỗi :
    nó báo lỗi trong khi write flash bạn có nâng cấp version cao hơn để thử rổi tính tiếp
    ****daithanh mobile****tienthanhfpt@hcm.fpt.vn ***
    Thành viên tích cực minhthucmobile's Avatar
    Sóc Sơn -Hà Nội
    mang sang HWK chạy lại xem bạn ơi.
    yahoo and skype:minhthucmobile
    đã chạy lên ok nhưng vẫn nghe nhac mất nguồn log info bằng mxkey vẫn như vậy. repair SD
    Vi phạm nội quy tuyetnhi_2007's Avatar
    log check của anh vẩn đẹp mà anh không có vấn để gì anh ạ . anh tes thử cục pin còn tốt xem nghe nhac thử xem
    Trích Được post bởi tuyetnhi_2007 Xem bài viết
    thì vậy mới có chuyện
    pin còn dầy đã thử pin khác và thay loa, mình nghĩ em nó bị lỗi ổ cứng vì em này không có thẻ ngoài
  1. e71 nghe nhac mất nguồn
    By thanhnghiaanh in forum BB5
    Bài viết cuối: 23-11-2011, 19:41
  2. Trả lời: 4
    Bài viết cuối: 09-07-2011, 18:35
  3. 3110c nghe nhac nửa bài mất nguồn
    By hehe6922 in forum BB5
    Trả lời: 28
    Bài viết cuối: 11-06-2011, 10:11
  4. 6270 nghe nhac tắt nguồn
    By mainhancon in forum BB5
    Bài viết cuối: 01-03-2010, 19:38
  5. 6233 nghe nhac xập nguồn
    By tiepmobile in forum BB5
    Bài viết cuối: 17-10-2008, 11:49
