em mới nhận cây 1202 rớt nước vệ sinh kỹ rồi mà kim chỉ nhích lên chút rớt xuống! em đã làm con U, nguồn rồi giờ máy có dao động rồi nhưng cũng ko lên nguồn . xin mây bác chỉ giúp !
đây là log của em nó
JAF version 1.98.62
Detected PKEY: 90009B6C
Card life counter: 99.99%
Detected version: 01.B1, Driver version: 0, Library version: 0
USB Cable Driver version: 7.0.2.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 03.10
21-01-09
RH-112
(c) NMP
HW version: 1005
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_08w31_UPP
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 03.10
21-01-09
RH-112
(c) NMP
MR
ADSP SW version: V 03.10\n21-01-09\nRH-112\n(c) NMP\nmr
Production serial number: DRV184002
Product code: 0562324
Module code: 0204036
Basic production code: 0558505
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 357984034066187
IMEI spare to net: 3A 75 89 04 43 60 16 08
IMEI SV to net: 33 75 89 04 43 60 16 18 F5
Master Code: 3227126005
Phone type: RH-112, Software version: 03.10, Language Pack: MR
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
Setting local mode...
Reading product code...
Product Code: 0562324
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
No ini files found...
Done!
