    Thành viên mới hugomobile's Avatar
    Unhappy NOKIA 2626 RM-291 bấm vài giây treo máy
    log của em nó đậy
    vao set test LCD NOSINGAL
    Using device: POTATO BOX, FW ver: 01.B1
    Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
    Rpl backup already exist (C:\mobileEx\3.4\data\backup\35554401474961_BACK.r pl).
    Processing file: rm291__06.81.mcusw as MCU
    [DCT4,DCT4 ALGORITHM] size: 8.60 MB
    Supported Ids: 3040
    ASIC ID: 0x3040 [UPP_4M ver: 4.1]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
    UEM ID: 00058474:4E99DA60
    Area [01000000-0101FFFF] erased in 0.859 s
    Area [01020000-018DFFFF] erased in 1 min 2.938 s
    Area [01EE0000-01FDFFFF] erased in 6.500 s
    Flash programming ...
    Programming completed in 1 min 2.140 s
    File Processed in 2 min 28.844 s
    Processing file: rm291__06.81.image_viet as CNT
    [DCT4,DCT4 ALGORITHM] page size: 64 K size: 2.00 MB
    Supported Ids: 3040
    UEM ID: 00058474:C5A4DA78
    Area [01B80000-01EDFFFF] erased in 22.672 s
    Programming completed in 14.531 s
    Extracting Content Pack, (c) Nokia File Server
    Content Pack extracted successfully in 0.063 s
    File Processed in 1 min 11.609 s
    Processing file: rm291__06.81.ppm_v as PPM
    [DCT4,DCT4 ALGORITHM] size: 2.42 MB
    Supported Ids: 3040
    UEM ID: 00058474:2984DA60
    Area [018E0000-01B7FFFF] erased in 18.781 s
    Programming completed in 17.578 s
    File Processed in 52.922 s
    Flashing completed in 4 min 45.171 s
    Phone Type: RM-291 (Nokia 2626)
    SW Version: V 06.81 05-11-08 RM-291 (c) Nokia.
    Imei plain: 35554401474961-6
    Product Code: 0545737
    Cellular System: GSM
    ASIC ID: 0x3040, type: 11
    Ppm Id: V
    Language Pack:
    - not available.
    Imei net: 35554401474961
    Version: SIMLOCK SERVER VERSION 63
    Provider: ALL Operator, Country: -
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 800000000001000B
    BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
    Total time to process is 5 min 9.906 s
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 1.265 s
    máy thường xuyên treo con này chưa đả động gì đến HW cả
    lúc trước gặp mấy con giống vậy làm hết bài vẫn vậy đành trả khách
    hjx
    Thành viên chính thức Anminhgsm's Avatar
    máy có bị rớt nước hay va đập gì không anh?log nhìn cũng ok, anh chạy lại 2610 Rh-86 xem thế nào,ko được anh làm ic phím thử vẫn not ok thì múc cpu nhé. Good luck
    Thành viên tích cực tuananh65's Avatar
    Feb 2008
    Hà nội
    Trích Được post bởi Anminhgsm Xem bài viết
    những co này thường hay bị ic phím dẫn đến treo,ban thay thử xem thế nào.chúc thành công
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    con này chuyên đề của nó nằm ở chổ con cpu đó anh
    thay u là giải phát good
    văn yên_yên bái
    Trích Được post bởi vudenproo Xem bài viết
    chích xác là ở cpu và UEM chắc chắn không phải lỗi do ic phím tránh làm tràn lan .được cái lọ mất cái kia
    Dec 2008
    Phù Tiên
    cái này cứ cho nó con u khac nap ver full là ok thôi
    Thành viên chính thức nguyễnphong's Avatar
    Mar 2010
    cpu rồi bạn ơi mình vừa làm xong một em cũng như vậy cứ bấm vài phím là đứng im hà
    Thành viên mới hoangminh_gms's Avatar
    May 2014
    mình vừa làm xong một cây như vậy thay cpu chay ver cao nhất ok
    Thành viên mới loibui879's Avatar
    May 2010
    mình đã gặp thay con thạch anh ok
  1. 2626 treo máy
    By ngocmobile1 in forum DCT4 - WD2
    Trả lời: 21
    Bài viết cuối: 06-07-2012, 16:22
  2. 2626 treo may
    By tanthiet_90 in forum DCT4 - WD2
    Bài viết cuối: 29-12-2010, 10:30
  3. 2626 rớt nước bị treo
    By theanh132 in forum DCT4 - WD2
    Bài viết cuối: 21-10-2008, 07:22
  4. 2626 treo fim
    By trinhnho in forum DCT4 - WD2
    Bài viết cuối: 30-09-2008, 17:37
  5. 2626 về chế độ chờ là treo
    By tuanhuong_lucky in forum DCT4 - WD2
    Bài viết cuối: 17-08-2008, 09:54
