máy bị mất nguồn em cạy keo đóng lại con nguồn, bây giờ bấm mở nguồn thì bi CS
đây là log cua em nó
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 7.02
10-12-07
RH-93
(c) NMP
HW version: 0526
PCI version:
UEM version: 1328
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 7.02
10-12-07
RH-93
(c) NMP
MD
ADSP SW version: no NAI version
Production serial number: KIO745705
Product code: 0533137
Module code: 0203167
Basic production code: 0532665
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 358994013715315
IMEI spare to net: 3A 85 99 04 31 17 35 01
IMEI SV to net: 33 85 99 04 31 17 35 41 F5
Master Code: 5507555132
Phone type: RH-93, Software version: 7.02, Language Pack: MD
User code: ÿ#
Block 1:
Lock 1: CLOSED -> Lock Data: 00101F
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
Setting local mode...
Reading product code...
Product Code: 0533137
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Checking path: \Products\RH-93\
No ini files found...
Done!
mấy bác giúp em tí, thank cả nhà !
