Kết quả 1 tới 10 của 13
    Thành viên mới vantruonguss's Avatar
    Mặc định n70 mất nguồn!!!!
    xin các cao thủ gúp đỡ n70 mất nguồn!
    tình hình là em nhận con n70 mất nguồn.em chạy pm bằng hộp jaf thì báo lỗi ,kết quả như sau:
    JAF version 1.98.62
    Detected PKEY: 90009699
    Card life counter: 99.99%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
    USB Cable Driver version: 7.1.21.0
    Changing mode...Done!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101002200
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 03A0010FAC954F51F704573B4ED991569ADB1C1B
    HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
    ROM ID: F28A211FCEA7B19D
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
    Loader version: 01.15.00 -> Revision: 0000
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 01.21.01 -> Revision: 0000
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05wk07v48.1
    28-08-07
    RM-84
    (c) Nokia.
    HW version: 6061
    PCI version:
    RFIC version: 150a160f
    DSP version: rolf_05wk07v29p1
    Retu version: 32
    Tahvo version: 53
    Production serial number: CIJ818907
    Product code: 0536418
    Module code:
    Basic production code: 0522156
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 359381007210413
    IMEI spare to net: 3A 95 83 01 70 12 40 01
    IMEI SV to net: 33 95 83 01 70 12 40 11 F2
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini
    Setting local mode...
    Reading product code...
    Product Code: 0536418
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\
    Scanning for ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V21
    APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.UDA
    Done!
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V01
    APE Variant file: ?
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Reading CMT NPC certificate...
    Reading CMT VARIANT certificate...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35938100721041_CRT_backup _1614196.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\359381007210413_CRT_backu p_1615196.pm
    Done!
    Backup LCK OK!
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Sending CNF Data...
    APE blocks present in flash file but no APE mcu detected in phone. Aborting!
    vậy là do đâu???????nó báo vậy là do lỗi con gì.bước tiếp theo em phải làm gì
    các anh em cao thủ xin giúp một tay.xin cảm on!!!!
    sao không ai gúp mình vậy? các anh có cao kiến gì giúp mình với!!!
    Thành viên tích cực sgh-x660's Avatar
    tìm hình câu áp đi bạn,search lại đi,thấy nói nhiều trên diễn đàn rồi
    cửa hàng DTDD Thanh Lâm , Hà Lam_Thăng Bình_Quãng Nam ,
    yahoo : thanhlam_tb1987
    Jan 2009
    Mở ất mất sắc mất ờ a pờ e rồi nạ, à quên, mất áp APE rồi chủ thớt câu lại đi là ok á
    cảm ơn mấy bu! hôm bữa đo áp ma quên do áp APE ,nay nhìn lại đúng la thiếu con n4201(ap APE) hixxx!!!...
    giúp em với,em đã đóng con n420, ap ape 1.8v co dủ rồi mà vẫn báo như vậy:
    em cũng đã nạp file rm-84 v5.73. mà cũng vay.may chk, inf ok cứ đang chạy thì báo như vậy
    Thành viên kỳ cựu THANH TRUNG's Avatar
    Kiên Giang
    câu lại thử xem.
    Đời khốn nạn khi em bỏ ra đi.
    Post
    tình hình là thế này các bác xem thủ: em đã đo va thấy các áp nhu hình:
    Thành viên tích cực tuananh65's Avatar
    Feb 2008
    Hà nội
    Trích Được post bởi THANH TRUNG Xem bài viết
    câu lại thử xem.
    đưa sang hwk quạt cấi là ok
    Thành viên tích cực trangiaminh's Avatar
    cho vào hwk hoặc mx key thử xem
    người ta sửa máy thì tài,tôi đây sửa máy khò uem chết cpu;)yahoo ...[love_forever_260l
