Phoenix Service Software 2010.24.003.43250 Cracked
NEW MULTI PROTOCOL PHOENIX SERVICE SOFTWARE VERSION 2010.24.003.43250
1.Change History:
• Version 1 2.7.2010 Initial version
Please note:
• This version contains the latest Tucson components. Therefore it is not necessary to use Tucson Add-On Installation Package v.2010_10_9_41709.
• Improvements concerning the case where phone models request SIM Lock data to be written in wrong format have been included. Therefore it is not necessary to use special DLL´s or Tucson Add-On Components for SIM Lock versions anymore.
• For all Tucson activities, use of components included in this release is enough, please do not use any previously released Tucson – related dll´s or add on packages
Main component versions in the release:
• DK2 Driver Version 07.14.0.25
• Nokia Connectivity Cable USB Driver Version 7.1.27.0
• Flash Update Package 10.20.001
• FLS-x Drivers Version 2.09.28
2. Main changes & error corrections from previous version 2010.12.11.42838
New Products added
• RM-684, RM-718, RM-693, RX-83, RX-85, RM-702, RM-688, RM-694, RM-695, RM-709, RM-639, RM-683, RM-666, RM-667, RM-712, RM-704, RM-711, RM-675, RH-125, RM-692
New features
• Connection refresh – button added directly to Phoenix UI. Refreshing connection is now possible without opening FUSE Connection Manager separately, use of older “manual CU-4 initialization” – menu is not needed if CU-4 is paired with the connection and “refresh” – function is used.
• New version of FUSE connection Manager
• New version of Flash Update Package
• Phoenix can now use product codes which contain alpha characters in addition to numbers
Error Corrections & changes
• EM Calibration and RSSI Reading improvements for RM-497 and products using same engine
• Improvements for ALS Calibration in Light Swap Modules
• Improvements to FM radio control
• Improvements to touch display testing
• Improvements to label printing alignment, displaying factory list and label printer setup
• Correction to problems when DP path contains diacritical signs
• Improvements to proximity sensor UI size
• Flashing improvements for RX-51
• Improvements to phone information reading
• Improvements for CU-4 use and connectivity
• Some obsolete product specific testing menu’s removed from all products in package
- PPC analyzer
- PPC online
- PPC reporting
- FPS-8C Flash
- FPS-8C Flash Pro
- FPS-11 Flash
- FPS-8C maintenance
- Bluetooth flasher
- Flash memory test
- WIMAX Autotune
- Show stored tunings
- PPC/Fault log archive & send
- Certificate backup tool
3. Known errors & limitations
• Software downgrade with Tucson system is only possible for BB 5.0 products supporting the Data Package 2 concept.
• Flashing with setup FLS-5, SS-46 and product specific adapter is not supported anymore
• If you install old DCT-4 data packages, Flash Update Package File installation path may be wrong. This is caused by very old DCT-4 data packages which contain Flash Update Package and overwrite current information during installation. If you experience problems when updating FPS-x prommers, please check that Phoenix “Prommer maintenance” is looking for the files from the correct location which is “C:\Program Files\Common Files\Nokia\Tss\Flash”. If not, Phoenix will show error “Update via ini – file failed”. In this case, select “Update” from that Phoenix “Prommer maintenance” – UI, browse to correct directory and select “fpsxupd.ini” for all other prommers except the FPS-8.
• Refurbishment flashing and product code change for RX-51 product requires SX-4 card to be available
• FPS-21 flashing for RX-51 works only with TCPIP connection. FPS-21 prommer with new HW version is needed to correct this, and it is estimated to be available by the end of 2010
• Please refer to product specific documents and instructions concerning the limitations of the RX-51 product
• RX-51 flashing does not work when CU-4 is used
• When version 2010_12_8_42304 or newer with FUSE connection manager is installed on top of older Phoenix versions, there may be an additional delay of several minutes when you start Phoenix for the first time. Please wait patiently; Phoenix will start after configuration is finished.
• When using Data Package download functions with online connection, download times may occasionally be long. This is not caused by Phoenix (or Care Suite). The download speed from online servers is occasionally is known to be slow, depending on how data is buffered on caching servers.
• Note concerning the installation and use with Administrator and User rights
- If you install Phoenix, start Phoenix and configure connections from FUSE connection manager as Administrator, you may not be able to start Phoenix after you log off and try to use Phoenix with User Rights afterwards
• If you experience the above mentioned problem:
- Log on as Administrator
- Deleted Fuse folder and its contents from: C:\Documents and Settings\All Users\Application Data\Nokia\
- After this Fuse’s connection list will be empty and it can be used directly with guest/admin rights.
- This has to be done only once.
• After you close Phoenix, it may not restart. To rectify this:
- Use Windows Task Manager to manually shut down phoenix.exe and FuseService.exe processes, or optionally restart your PC
• Mass memory content file flashing does not work for all products over USB – FPS-10 or FPS-21 Flash Prommer must be used!
Supported operating systems and user rights
Windows XP Service Pack 1 or higher
When installing Phoenix into Win XP you must have local admin rights.
When using in Win XP, user must have power user rights.
For HW & Tool requirements please refer to to Recommended hardware for PC.
For information on product specific data packages, tools and instructions please refer to service manuals and technical bulletins.
If you are installing this version of Phoenix on a new Imaged PC, and you are using an FLS-4S or FLS-5 during the install, then install the FLS-X drivers first.
Link:RapidShare: 1-CLICK Web hosting - Easy Filehosting
PS: Tested ok by me vừa test ok N95 flash ok
