1208 tình trạng của em nó như sao:máy đang xài bình thường tự nhiên đen thui màng hình treo máy.main con ok flash ok từ A->Z nhưng vẩn vậy:thay CPU FLASH lại củng thế sao đây là log của em nó.mong các anh em trong diển đàn giúp đở và có ai làm được xin chia sẻ:
JAF version 1.98.66 beta5
Detected PKEY: 90014797
Detected version: 01.B4, Driver version: 0, Library version: 0
USB Cable Driver version: 7.1.29.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_06.000
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_06.00ma
Languages in ppm: English,Chinese S,Chinese T,Vietnamese,Filipino
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai6.00ma
Setting local mode...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_06.000
Booting phone...
MCU ID: 0x2292
Loader version: 04.4F.00 -> Revision: 0007
Boot size is 0x09D8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4C68; Loader chk: ff
Loader is ready...
MSID: 846A68C34740AB1F45706FAE30
MSID decoded: 3E4EBAE9004F349AA8000000
FAID: D5F1F60A52B363F9ED8B91BD
Erasing...
Found 5 interval(s) to erase
Operation took 1 minutes 30 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 15 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_06.00ma
Booting phone...
MCU ID: 0x2292
Boot size is 0x09D8
Boot is ready...
Loader is ready...
MSID: 84FC7A64544655065B8DCCA654
MSID decoded: 3E4EBAE9004F349AA9000000
FAID: 70596EF8033A35FE3439A7F5
Erasing PPM...
Found 2 interval(s) to erase
Operation took 0 minutes 28 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai6.00ma
Booting phone...
MCU ID: 0x2292
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 3 minutes 20 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-105, Software version: 6.00
IMEI: 354868023705165
Product Code: 0549934
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Done!
Done!
Powering the phone...
Unlocking...
ASIC: b
SW version: 6.00
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_06.000
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 02
MCU ID: 0x2292
Algo is ready...
Erasing area: 01200000 - 0121FFFF...
Erasing area: 011E0000 - 011FFFFF...
Unlocking...
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 1
Done!
