    Thành viên chính thức quocdaiho's Avatar
    Mặc định Các huynh xem hộ em cái log 1208 này với
    Getting MCU ID
    MCU ID: 0x2292
    FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-105\
    No ini files found...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.910
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.91mr
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.91mr
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.910
    Booting phone...
    MCU ID: 0x2292
    Loader version: 04.4F.00 -> Revision: 0007
    Boot size is 0x09D8
    Boot is ready...
    Flash ID is 0x6822EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x78C8; Loader chk: cc
    Loader is ready...
    MSID: 84A6F41E2F161741712F571930
    MSID decoded: 3E4EBAE900D9DD77A8000000
    FAID: DB76FC72CBC6C0FE82018E4D
    Erasing...
    Found 5 interval(s) to erase
    Operation took 0 minutes 26 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.91mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.91mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    MSID: 84466F3C2723FD4750533FFF43
    MSID decoded: 3E4EBAE900D9DD77AA000000
    FAID: E894D3E1A0079E4532A60C0B
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 1 minutes 36 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-105, Software version: 5.91
    IMEI: 352930028552471
    Product Code:
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Powering the phone...
    Unlocking...
    ASIC: b
    SW version: 5.91
    Selected flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.910
    Decrypting flash...
    Encrypting....
    CHK Patch found - Unlock Patch found and are not in same block
    Patch status: 01
    MCU ID: 0x2292
    Algo is ready...
    Erasing area: 01160000 - 0117FFFF...
    Unlocking...
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    MCU ID: 0x2292
    Algo is ready...
    Done!
    DCT4 unlock counter: 14
    Done!
    e chạy xong nó báo contact service là sao vậy các huynh. thanks các huynh trước
    Thành viên tích cực ĐìnhThắngMobile™'s Avatar
    GSMobifone
    Không bít tình trạng lúc đầu thế nào.Bạn xóa full nạp lại xem sao.Nhớ là write pm=>factory nhé,rồi tính tiếp
    lúc ban đầu máy khởi động xong là treo. e đã chạy ver 5.91 factory rùi mà vẫn vậy. e đã làm lại CPU, có cách nào không mấyhuynh
    Oct 2009
    tân phú-đồng nai
    Trích Được post bởi quocdaiho Xem bài viết
    chạy lại ver này coi seo heng bạn 1208
    Thành viên tích cực phu quy's Avatar
    Sep 2007
    bạn vệ sinh sạch cái màn hình đi hoặc thay cái khác xem con này bị như thế hay do màn lắm . chúc thành công !
    QUÊ HƯƠNG HƯNG ĐẠO VƯƠNG
    V.I.P HUE_GSM's Avatar
    Mar 2008
    Đến từ Huế city.
    Thay con cpu khác rồi chạy sw lại cái ok thôi bạn hiền.
    Thành viên chính thức hoang_hai's Avatar
    Mar 2010
    TP bắc ninh
    Reading...
    Product Code:
    Resetting PPC...
    Done!
    Done! trông đẹp lăm bạn ạ
    Thành viên tích cực motlamlemobi's Avatar
    Dec 2007
    Getting MCU ID
    MCU ID: 0x2292
    Algo is ready...
    Done!
    Phone Restarted...
    Phone Type:
    Phone Type:
    Phone Type:
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    Writing...
    Restarting MCU...
    Flashing Done!
    Reading...
    Product Code:
    Resetting PPC...
    Done!
    Done!
    Unlocking...
    ASIC: b
    SW version: 5.91
    Decrypting flash...
    Encrypting....
    Patch status: 01
    MCU ID: 0x2292
    Algo is ready...
    Unlocking...
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    MCU ID: 0x2292
    Algo is ready...
    Done!
    Done!
    bạn chạy song phỉa actory là ok đó đường làm phần cứng bạn làm không hết đâu chúc bạn thành công
    CO DON MJNH ANH
    YAHOO! MMOTYEUEM.DT 0979414242
  1. các huynh oi!
    By minhtinhmobile in forum Advance Turbo Flasher
    Bài viết cuối: 11-10-2012, 21:13
  2. Trả lời: 4
    Bài viết cuối: 23-01-2010, 17:13
  3. mấy huynh cho em hỏi
    By htqs1619 in forum DCT4 - WD2
    Bài viết cuối: 08-12-2009, 16:39
  4. hoc hỏi các huynh mong các huynh giup
    By _Kyo_ in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 14-08-2009, 17:24
  5. Trả lời: 5
    Bài viết cuối: 02-12-2008, 22:44
