tình hình là máy mới vào bat nguồn rung rồi treo xanh mang hình , em đóng lại con omap giờ lên được nokia nhưng treo, flat lại bang mt_thì khong được, con bang mxkey file mcu được nủa chừng thì đá ra, pro nào gặp qua pan nay rồi thì giúp em với
mx_key báo vậy nà
Version from phone: 05wk47v62
Version from file: 4.0812.4.0.1
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Reading phone`s ID ...
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
ROM ID: 273F6D55DFAAF68F
productData saved.
Restarting phone ...
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B21
PUBLIC ID: 0FC001100EA40154DFC614AB6F24329C8FAA4A8B
ASIC MODE ID: 00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP
TransmissionMode: 16Bit
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
TransmissionMode: DDR&TX2
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0xB8 bytes).
Reading RAP CCC (0x0 bytes).
Reading RAP HWC (0x0 bytes).
Flash Imei: 35364101010977
NPC_DATA saved OK
VARIANT_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35364101010977_BA CK.rpl"
Processing file: N73_4.0812.4.0.1_western_C00_PRD_cc.fpsx as MCU
[BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 46.94 MB
Supported APE Ids: 17100708
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B21
ASIC MODE ID: 00
Partitioning ...OK
Erase size: 91.38 MB
CMT NOR area [00080000-0073194D] erased in 31.750 s
CMT NOR area [00000000-0005FFFF] erased in 0.578 s
CMT NOR area [001E0000-001FFFFF] erased in 0.172 s
CMT NOR area [00880000-00FEFFFF] erased in 7.578 s
APE NAND area [00000000-0007FFFF] erased in 0.140 s
warning : erase sector address out of chip bound.
APE NAND area [00080000-000FFFFF] erased in 0.156 s
APE NAND area [00100000-0025FFFF] erased in 0.157 s
APE NAND area [003C0000-04E1FFFF] erased in 0.156 s
Flash programming ...
CMT PAPUBKEYS: 5E8D0D504A0902E261268C14FCD8A2C9093523BC (Rap Certificate 26 v1) written.
Error chk C7012D0100D0000010000000F1
Error while programming [01] at 0x00000000, Result: 0010
Flashing terminated with error(s) in 2 min 43.141 s
RX Buffer: C7012D0100D0000010000000F172
