tình trạng máy rơi nước em đã vệ sinh kĩ chạy bằng jaf thì ok info đc nhưng ko lên nguồn chạy bằng mx và hwk thì báo lỗi
đây là log của mxkey
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00288AA0A3BDA66
ASIC type: 11
UEM Imei: 35692503129181
Processing file: rh112_004.030 as MCU
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
UEM ID: 00288AA0:2984DA60
Area [01000000-0100FFFF] erased in 1.047 s
Area [01010000-013AFFFF] erased in 59.141 s
Area [013B0000-013EFFFF] erased in 4.188 s
Area [017C0000-017EFFFF] erased in 0.219 s
Area [01FC0000-01FEFFFF] erased in 0.203 s
Flash programming ...
Programming completed in 19.250 s
File Processed in 1 min 32.343 s
Processing file: rh1120_nai04.03mr as CNT
[DCT4,DCT4 ALGORITHM] size: 110.54 KB
Supported Ids: 2293
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Area [01380000-013AFFFF] erased in 3.171 s
Programming completed in 1.078 s
Content extract fail, continue anyway ...
File Processed in 11 min 35.563 s
Processing file: rh112_004.03mr as PPM
[DCT4,DCT4 ALGORITHM] size: 1.15 MB
Supported Ids: 2293
Area [01240000-0124FFFF] erased in 1.047 s
Area [01250000-0137FFFF] erased in 19.375 s
Programming completed in 9.344 s
File Processed in 40.312 s
Flashing completed in 14 min 42.437 s
Phone not responding !
Total time to process is 15 min 11.453 s
mong ae chỉ giáo thank all
