6230 để trong tủ chưng khách vô mua lấy ra bật k lên nguồn đem vô cấp nguồn k dao động gì hết cho vô box jaf chest k đc nhờ ae xem hộ log nó đây
Phone didn't answer with TX line low after UEM reset!
Causes:
1. put a 27-33 pico capacitor in connector b/w mbus-gnd.
2. UEM damaged -> replace uem.
MCU ID: 0xDDDD
Failed! Aborting!
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-12\
Checking path: \Products\RH-12\
No ini files found...
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\products\rh_12\rh12_28_11005.5 00
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\products\rh_12\rh12_28_11005.5 0v
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\products\rh_12\rh12_28_11005.5 0.ucp_v
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\products\rh_12\rh12_28_11005.5 00
Booting phone...
Phone didn't answer to request flash routine!
Causes:
1. UPP damaged -> replace UPP
MCU ID: 0xEEEE
This MCU ID is not supported in chosen flash file...
Error booting phone...
Failed! Aborting!
Booting phone...
FAILED ->jaf configuration 2
Causes:
MCU ID: 0xDDDD
Failed! Aborting!
Booting phone...
Causes:
MCU ID: 0xEEEE
