Kết quả 1 tới 10 của 11
    vĩnh phúc
    Mặc định 110i chết nguồn
    em mới nhận con 110i khách nói tự nhiên chết nguồn, em chạy pm thì nó lên được chữ NOKIA rồi đứng im ở đó luôn, em khò nhẹ vào u thì nó ngủ luôn. em chạy lại log đây ạ:
    Getting MCU ID
    MCU ID: 0x2201
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Failed! Aborting!
    Phone Type:
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.02md
    Languages in ppm: English,Filipino,Vietnamase
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh930_nai7.02md
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
    Loader size is 0x5538; Loader chk: bb
    Loader is ready...
    MSID: 8417B8A0504D986450272ACDB6
    MSID decoded: 3E4EBAE9004B0613AA000000
    FAID: 79D18542DCD9D431C686BCB2
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 36 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 16 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.02md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 011E0000 - 011EFFFF...
    Erasing area: 011F0000 - 0137FFFF...
    Operation took 0 minutes 15 seconds...
    Writing...
    Operation took 0 minutes 13 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh930_nai7.02md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 847B3DF9E1A88C649242AECFBD
    MSID decoded: 3E4EBAE9004B0613A8000000
    FAID: 032AFA0A417C318185531AF8
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013BFFFF...
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 22 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    mong các bác giúp em. giờ nó lên chữ NKIA rồi nhưng vẫn thế ạ
  1. Trả lời: 4
    Bài viết cuối: 25-10-2012, 18:17
  2. cần mua day usb của 1200 110i 1202 để chạy pm
    By yb_pro2012 in forum DCT4 - WD2
    Bài viết cuối: 02-10-2012, 09:07
  3. cần giúp 110i sóng chập chờn
    By lethanhtam92 in forum DCT4 - WD2
    Bài viết cuối: 16-05-2012, 21:47
  4. 110i chạm nguồn
    By qkmobile_kcr in forum DCT4 - WD2
    Bài viết cuối: 09-11-2011, 17:20
  5. 110i tự nhiên chết nguồn
    By toanmobile88 in forum DCT3-DCTL
    Trả lời: 21
    Bài viết cuối: 07-10-2010, 09:27
