Kết quả 1 tới 10 của 13
    Thành viên mới nhatphongbg's Avatar
    Mặc định xem hộ mình phần mềm con 1200 này với. giờ nó bị contacsevit.
    Getting MCU ID
    MCU ID: 0x2292
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.710
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.71mr
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai5.71mr
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.710
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: d9
    Loader is ready...
    MSID: 844EB5E6611E1C83D3CF90BFCA
    MSID decoded: 3E4EBAE900492993AA000000
    FAID: B70F7324F94316652EE251A0
    Erasing...
    Found 5 interval(s) to erase
    Operation took 0 minutes 44 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 18 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.71mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 844AE55642DEFD86B019BEF904
    MSID decoded: 3E4EBAE900492993A8000000
    FAID: 58694A443853F4DBD1D7A5D1
    Erasing PPM...
    Found 2 interval(s) to erase
    Writing...
    Operation took 0 minutes 9 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai5.71mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 6 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    và đây là chạy qua N-box:
    1st Boot: Ok, DCT4, UPP: 2292 [Rh-99] [2.1.0.0]
    2nd Boot: u3_2nd.fia, Ver: 4.79.0
    Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18
    Algorithm: u3_intel.fia, Ver: 4.80.0
    Algorithm Ok, MSID: 844EB5E6611E1C83D3CF90BFCA
    Decoded MSID: 3E4EBAE9-00492993-AA000000
    Encoded FAID: B70F7324-F9431665-2EE251A0
    IMAGE: rh99_05.710
    Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
    Area2: 0x01010000-0x013AFFFF Erased, Time: 00:38
    Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03
    Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
    Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
    MCU Flashing Completed, Time: 00:19
    IMAGE: rh990_nai5.71aa
    Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01
    CNT Flashing Completed, Time: 00:01
    Init Local Mode Failed
    check được nhưng không info được. anh em chỉ cho mình cách chạy lại với.
    Thành viên tích cực trantukiet1008's Avatar
    Dec 2009
    chạy bằng mx key thử đi bạn.
    Thành viên tích cực liencuongmobile's Avatar
    Oct 2009
    Usa
    che chân vpp lại rồi hãy chạy xem sao anh
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    che chân số 6 lại đi bạn. đảm bảo chạy rầm rầm
    korea
    cũng khó nói chính xác máy bị làm sao . vì không biết máy tự dưng bị hay va dập vô nước . nhưng nhìn log thấy máy chưa vào dc chế độ locad mode .lỗi này có thể do cáp ... nhưng cúng có thể do lỗi cpu - flast cũng gây nên . bạn kiểm tra cáp chạy lại , rồi check lại flast -cpu. chỉ có thể góp ý như zaayj . chúc bạn thành công . thân .
    Mặc định lí do nó bị contacsevit la:
    minh cho vào full factory defaults. đang làm thì bị tuột tay và nó bị thế. còn ban đầu máy vẫn sống bt mà. ko bị va đập hay rơi nước gì cả.
    Vi phạm nội quy tuyetnhi_2007's Avatar
    anh kiểm tra cáp.. xoa full chạy lại .. che lại chân vpp luôn anh.. chạy lại xem thử nha anh chúc anh
    Thành viên tích cực honghai.com's Avatar
    cũng có trường hợp phải đóng lại hoặc thay ic & nạp file chuẩn mới hết bệnh.Chúc may mắn
  1. 1200 bị contacsevit cần giúp
    By thuongmobi5 in forum DCT4 - WD2
    Bài viết cuối: 10-03-2013, 12:57
  2. 1200 bi loi contacsevit
    By longnhat_vn1985 in forum DCT4 - WD2
    Bài viết cuối: 14-02-2011, 12:12
  3. 1200 lỗi phần mềm
    By tmpmobile in forum DCT4 - WD2
    Trả lời: 19
    Bài viết cuối: 02-10-2009, 20:40
  4. 1200 sumosim chậy phần mềm bi contacsevit
    By langngo in forum DCT4 - WD2
    Trả lời: 19
    Bài viết cuối: 07-09-2009, 13:00
  5. Nokia 1200 bị contacsevit
    By dangquangbmt in forum DCT4 - WD2
    Trả lời: 16
    Bài viết cuối: 29-10-2008, 22:43
