các Mod, các Pro xem dùm cái log
AF version 1.98.66 beta5
Detected PKEY: 90019A02
Detected JAF INTERFACE version: 01.B4, Driver version: 40000, Library version: 30107
USB Cable Driver version: 6.86.11.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_67PE605250.C2
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605250.31
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_67PE605250.C2
Booting phone...
MCU ID: 0x1081
BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
Boot size is 0x10D8
Boot is ready...
FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Flash ID is 0x22F800EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
Loader size is 0x7F10; Loader chk: ac
Loader is ready...
MSID: 84C2E663CF5849280D3CDC62C7
MSID decoded: 3E4EBAF700C18F43A9000000
FAID: 1BB8A4288F285B1C0A84A02B
Operation took 0 minutes 19 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 00FFFFFF...
Erasing area: 02000000 - 029FFFFF...
Erasing area: 02FC0000 - 02FEFFFF...
Operation took 3 minutes 44 seconds...
Writing...
Perm. Data Restore OK
Operation took 3 minutes 23 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605250.31
Booting phone...
MCU ID: 0x1081
Boot size is 0x10D8
Boot is ready...
Loader is ready...
MSID: 84AF70B57A59757B04D04C616E
MSID decoded: 3E4EBAF700C18F43A8000000
FAID: F92387A5C2DB9C9280BABF87
Operation took 0 minutes 20 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 02B00000 - 02D6FFFF...
Operation took 0 minutes 21 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 9 minutes 5 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Failed! Aborting!...MCUVER
bây giờ phải làm sao các Mod, các Pro ơi
thanks thanks thanks!
