    Product Manager Hoang Thong Mobile's Avatar
    Dec 2006
    Mặc định << NBA - Nokia Battery Adapter - we are FIRST IN THE WORLD AGAIN >>
    powered by UFC3GS in collaboration with MXKEY Team
    Giá : 90.000 VND cho 10 cái NBA
    The NBA it's a revolution in itself:
    Small, Smart, Cheap, Usefull, Solid, Strong, Compatible, everythink you can wish for.
    Features:
    - powerful catch, stronger than usual battery connectors
    - you will be finally able to rest assure that your phone will finish flashing without unwanted interruptions
    - simple to use, just connect it inside your mobile phone as shown in the pictures
    - small yet big enough to use your hand to attach or remove
    - compatible with over 71 Nokia phone models and more than 10 battery types
    - compatible with all crocodile style connectors used by most of GSM product manufacturers
    - durable, make from quality materials
    - high quality gold plated connector pins
    - special designed connector with quality ABS plastic
    - solder wires to it and you can forget about problems
    - double sided PCB
    Built using:
    - high quality smart design PCB
    - custom made gold plated PINS
    - custom made special connector plastic with special shape to fit all Nokia phone that use this style of connectors
    - 3 double sided holes to fit any crocodile type connector
    - large metal pads to easy solder your custom power cable directly to it
    works with any Nokia mobile phones that uses this type of battery conector.
    There are many ways you can use the NBA. Here is just a few of them.
    CTY TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    ĐT/FAX : 083.9572152 - 08.38575707 - 0903.303.717
    Skype : saigonmobile
    YM : saigonmobile_vn
    MSN : saigonmobile@hotmail.com
  2. ( Hoang Thong Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hanghuu (18-08-2010)
    V.I.P nhatkha's Avatar
    Feb 2006
    Trung Tâm Kha Oanh .
    Gửi cho em 1 bộ đi anh ơi.
    V.I.P hanghuu's Avatar
    Cổ tự Nghĩa
    Mai ra Nhựt Tảo mua tấm đồng + dung dịch về tận dụng mấy đầu pin cũ chế
    hanghuu1982@yahoo.com.vn
    0933.286.489
    Thành viên tích cực anhbo's Avatar
    Aug 2008
    còn cái của e là made in vietnam nè,tuy ko pro và chắc chắn như của admin nhưng giá thành cực rẻ,linh kiện có sẵn với ae mobile.chỉ cần 1 cục pin hư nokia 4b,4u,5f,6f...chế vào cáp đa năng boot ầm ầm
    Cổ tự Nghĩa
    Phá mồi admin quài
    0933.286.489
  1. Battery Plus - Pimp Your Battery
    By NAMMC in forum Ứng dụng dành cho Apple IPhone
    Bài viết cuối: 21-05-2014, 14:07
  2. Nokia 6303c Low battery after whitescreen 100% tested solution
    By jerrylevu in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 21-12-2010, 21:09
  3. << NBA - Nokia Battery Adapter - we are FIRST IN THE WORLD AGAIN >>
    By Hoang Thong Mobile in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 17-08-2010, 21:49
  4. Martech XC1 Adapter
    By buocphaisong in forum Martech
    Bài viết cuối: 06-08-2009, 18:57
  5. Hot sơ đồ adapter with RX2
    By huyanten in forum MT-Box
    Bài viết cuối: 19-05-2009, 17:15
