em nhận con 1661 lúc đầu bị bệnh bật nguồn để vài giờ tự mất mở lên lại được vai giờ nạp phần mềm không hết.Xóa full flash xong chạy lại giờ ccontact ,thay cpu từ con 1661 khác vào vẫn vậy nạp lại không được !bác nào gặp t/hợp này xin chỉ giáo.
Và đây là log của nó nhờ các ace xem giùm.
Getting MCU ID
MCU ID: 0x2293
FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-122\
Checking path: \Products\RH-122\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-122\rh122_003.360
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-122\rh122_003.36aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-122\rh1220_nai03.36aa
Languages in ppm: English,Dannish,Norwegian,Swedish
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-122\rh122_003.36mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-122\rh1220_nai03.36mr
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-122\rh122_003.360
Booting phone...
MCU ID: 0x2293
Loader version: 04.4F.00 -> Revision: 0007
Boot size is 0x09D8
Boot is ready...
Flash ID is 0xC0882000
Loader size is 0x4C68; Loader chk: 67
Loader is ready...
MSID: 8432CFAE1F3279B6ED562BE9E9
MSID decoded: 3E4EBAE900173403A8000000
FAID: 168DDBC7670DD7C719F041D9
Erasing...
Found 4 interval(s) to erase
Erasing area: 01010000 - 0179FFFF...
Erasing area: 017A0000 - 017EFFFF...
Erasing area: 01F00000 - 01FDFFFF...
Operation took 1 minutes 41 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 15 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-122\rh122_003.36mr
Booting phone...
MCU ID: 0x2293
Boot size is 0x09D8
Boot is ready...
Loader is ready...
MSID: 84C2DE28100F30F3F16886CC95
MSID decoded: 3E4EBAE900173403AA000000
FAID: C512FC11ED1C4BAE3C51349E
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0125FFFF...
Erasing area: 01260000 - 0175FFFF...
Operation took 1 minutes 5 seconds...
Writing...
Operation took 0 minutes 17 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-122\rh1220_nai03.36mr
Booting phone...
MCU ID: 0x2293
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01760000 - 0179FFFF...
Writing...
Restarting MCU...
Flashing Done!
Operation took 4 minutes 10 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Giờ em chưa giám xóa full .không unlock được.Write không được
			 1661 contact cervice
 cảm ơn các bác!!!
 cảm ơn các bác!!!
