tình hình là khách nói đang sài tự nhiên mất nguồn mình cho vào máy cấp nguồn nó lên trắng màn hình đc một chút là nó tắt , cho vô jaf chạy thì báo lỗi ae xem dùm log của em nó với
MCU ID: 0x1081
FLASH ID0: 007E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 007E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 277E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-51\
Checking path: \Products\RM-51\
No ini files found...
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\products\rm-51\RM51PE507170.C2
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\products\rm-51\RM51PE507170.6C
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\products\rm-51\RM51PE507170.1C
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\products\rm-51\RM51PE507170.C2
Booting phone...
MCU ID: 0x1081
BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
Boot size is 0x10D8
Boot is ready...
Flash ID is 0x007E0001
Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
Loader size is 0x7F10; Loader chk: c3
Loader is ready...
MSID: 8461CB95D9829B1AC8E1161507
MSID decoded: 3E4EBAF7005D6AFAA8000000
FAID: F7CD85365CD9814A8C0BD58D
Operation took 0 minutes 24 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 00FFFFFF...
Erasing area: 02000000 - 02CEFFFF...
Erasing area: 02FC0000 - 02FEFFFF...
Operation took 3 minutes 21 seconds...
Writing...
Perm. Data Restore OK
Operation took 4 minutes 1 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\products\rm-51\RM51PE507170.1C
Booting phone...
MCU ID: 0x1081
Boot size is 0x10D8
Boot is ready...
Loader is ready...
Operation took 0 minutes 25 seconds...
Erasing Content Pack...
Found 3 interval(s) to erase
Erasing area: 02D00000 - 02EFFFFF...
Erasing area: 04600000 - 047DFFFF...
Operation took 0 minutes 29 seconds...
Writing...
Operation took 0 minutes 33 seconds...
Restarting MCU...
Extracting Content Pack...
Error setting local mode...
CP Extract Failed!
PPM: C:\Program Files\Nokia\Phoenix\products\rm-51\RM51PE507170.6C
Booting phone...
MCU ID: 0x1081
Boot size is 0x10D8
Boot is ready...
Loader is ready...
MSID: 84718AA3D41D7484738F0DAD5E
MSID decoded: 3E4EBAF7005D6AFAAA000000
FAID: 8B77B546790F6FB1B66C35CA
Erasing PPM...
Erasing area: 04600000 - 047FFFFF...
Erasing area: 02F00000 - 02F1FFFF...
Operation took 0 minutes 31 seconds...
Writing...
Operation took 0 minutes 35 seconds...
Restarting MCU...
Flashing Done!
Operation took 11 minutes 52 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
