Whats new ?
[X] Added full support for ALCATEL OT-104/OT-223/OT-565.
[X] Updated the MTK download library to a new version so be sure you install
latest version over old file or even more delete all files besides security backups .
[X] should fix some OT - 208X connection problems reported by some users !
[X] Improved new flash type support and corrected and IMEI read problem.
[X] Added installer !
NOTE : You need to update Dongle for this new release.
SHORT TUTORIAL REGARDING ALCATELS WITH HARDWARE PROTECTION ENABLED
As you might know till know till now, there are some models not
connecting no matter the pinout used and this is because they
have removed from factory the I/O tracks.
You can check the enclosed photo. We marked it with the red circle.
The TX/RX PIN connection is cut by this drilled hole.
No external tool can connect it, our tool, Infinity, Polar, etc.
We know how to handle it manually.
Use a knife to scrape the PCB around this hole, you may find the break fuse,
try to connect them.
It is not easy, you may have a try.
But it is really out of our scope, software can not handle such hardware problem.
best regards,
FuriouSTeaM
			 24/08/2010 [PACK 8] ALCATEL MTK UNLOCK TOOL v1.0.0.12 by EASON RELEASED ! *HOT*
