    Thành viên chính thức vanhienkontum's Avatar
    Apr 2010
    Mặc định 1202 lỗi gì
    mình thay UEM , nạp Log thì báo Contacsvit mình xóa Full nạo lại báo lỗi sau , giờ khôngh lên nguồn
    Processing file: rh112_004.030
    ASIC ID: 0x2293 [UPPCosto ver: 2.0]
    u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8
    FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF
    ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
    u3_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528
    UEM ID: 00A4B9D5:2984DA60
    Programming MCU ...
    rh112_004.030:
    [DCT4,DCT4 ALGORITHM]
    Supported Ids: 2293
    Area [01000000-0100FFFF] erased in 0.359 s
    Area [01010000-013AFFFF] erased in 20.141 s
    Area [013B0000-013EFFFF] erased in 1.421 s
    Area [017C0000-017EFFFF] erased in 1.063 s
    Area [01FC0000-01FEFFFF] erased in 0.031 s
    Flash programming ...
    Programming completed in 14.469 s
    File Processed in 51.484 s
    Processing file: rh1120_nai04.03ic
    Programming Content Pack ...
    rh1120_nai04.03ic:
    Supported Ids: 2293
    Area [01380000-013AFFFF] erased in 1.062 s
    Programming completed in 1.047 s
    Content extract fail, continue anyway ...
    File Processed in 27.656 s
    Processing file: rh112_004.03ic
    Programming PPM ...
    rh112_004.03ic:
    Supported Ids: 2293
    Area [01240000-0124FFFF] erased in 0.344 s
    Area [01250000-0137FFFF] erased in 7.000 s
    Programming completed in 7.843 s
    File Processed in 29.422 s
    Flashing completed in 1 min 51.469 s
    Phone not responding !
    Total time to process is 2 min 14.578 s
    Apr 2010
    bên JAF báo như sau
    Getting MCU ID
    MCU ID: 0x2293
    FLASH ID0: 225400EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Phone Type:
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Documents and Settings\160987\Desktop\1202 RH-112_3.10\1202 RH-112_3.10\rh112_003.100
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    PPM Flash file: C:\Documents and Settings\160987\Desktop\1202 RH-112_3.10\1202 RH-112_3.10\rh112_003.10mr
    Phone Type:
    CNT Flash file: C:\Documents and Settings\160987\Desktop\1202 RH-112_3.10\1202 RH-112_3.10\rh1120_nai03.10mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Documents and Settings\160987\Desktop\1202 RH-112_3.10\1202 RH-112_3.10\rh112_003.100
    Booting phone...
    MCU ID: 0x2293
    Loader version: 04.4F.00 -> Revision: 0007
    Boot size is 0x09D8
    Boot is ready...
    Flash ID is 0x5422EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x78C8; Loader chk: 80
    Loader is ready...
    MSID: 844BE482CCE21F007A2CC85180
    MSID decoded: 3E4EBAE900A4B9D5A8000000
    FAID: 8FF47D993299F67D2A1C486C
    Erasing...
    Found 5 interval(s) to erase
    Operation took 0 minutes 32 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 27 seconds...
    Restarting MCU...
    PPM: C:\Documents and Settings\160987\Desktop\1202 RH-112_3.10\1202 RH-112_3.10\rh112_003.10mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    MSID: 84281C219BC0E32C4EADE79F52
    MSID decoded: 3E4EBAE900A4B9D5AA000000
    FAID: ED90F9A2F5EDCBE1FE330A42
    Erasing PPM...
    Found 2 interval(s) to erase
    Writing...
    Restarting MCU...
    CNT: C:\Documents and Settings\160987\Desktop\1202 RH-112_3.10\1202 RH-112_3.10\rh1120_nai03.10mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 38 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Thành viên chính thức minhgiang_mobile's Avatar
    Jun 2010
    Bị CPU rùi anh ơi. làm lại Hoặc thay mới đi là dc.
    YH : minh_giang_0108@yahoo.com.vn
    Jan 2007
    THAI BINH CITY
    llõi dồng bộ không đựoc bạn xoá lát đi chạy lại wri pm lại ulock cái cốic hết không của bạn bây giờ đang r\bị cotrac dúng không
    Thành viên mới h2t1990's Avatar
    Aug 2010
    a oi cho e xin pan mem JAF.e dơn tren mang rui nhung k cai dc.giup e voi.thak cac a
    Moderator TÚ CÒI's Avatar
    hà nội
    phần mềm setup JAF à.qua yahoo mình send cho.camtu_a13lnbg@yahoo.com
    By LEGIAM_GSM in forum DCT4 - WD2
    Bài viết cuối: 23-09-2012, 09:55
  2. 1202 mất mic
    By cuocsongmoi_hotbyos9x in forum DCT4 - WD2
    Bài viết cuối: 16-10-2010, 15:30
  3. 1202 không đồng bộ được
    By q79 in forum DCT4 - WD2
    Bài viết cuối: 12-10-2010, 18:19
  4. Trả lời: 0
    Bài viết cuối: 19-07-2010, 08:52
  5. Trả lời: 6
    Bài viết cuối: 15-02-2010, 09:38
