em có cây 1200 khi write RPL thì nó báo vậy
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 0042DF6CA3BDA66
Programming FLASH Imei ...
FLASH programmed successfully.
warning: For UEM write, VBAT needs to be atleast: 5.2V
Programming UEM Imei (OTP) ...
UEM programmed successfully.
Phone Type: RH-99
SW Version: V 5.71 12-09-08 RH-99 (c) NMP
Imei plain: ??????????????-?
Product Code: 0546885
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MR
Language Pack:
- not available.
Imei plain is invalid !!!
Imei net: 00000000000000
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000010000
SIMLOCK_DATA corrupted!
em không hiểu lắm
Mong các bác giúp em với
			 1200 không write được log
