mình dùng mx write imei xong không đồng bộ được,lắp sim vào thì máy báo sim không hợp lệ.ace giúp mình sử lý vụ này với,thanks.đây là log check em nó bằng mx key
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
UEM ID: 00DF17F7:2984DA60
ASIC type: 2
UEM Imei: 35867101032850
Flash Imei: 35867101032850
MasterCode: 0423344510
RPL saved to "C:\mobileEx\3.4\data\backup\35867101032850_BACK.r pl"
Phone Type: RH-93
SW Version: V 6.41 06-04-07 RH-93 (c) NMP
Imei plain: 35867101032850-4
Cellular System: GSM
ASIC ID: 0x2201, type: 2
Ppm Id: MD
Language Pack:
English,Filipino,Vietnamase
Imei net: 35867101032850
Version:
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: 0000000000010000
BLOCK 1: 1.CORRUPTED
			 log 1110i cần giúp
 log 1110i cần giúp
