anh em giúp với,máy còn ngon,mình chạy phần mềm bị contac
 2730c bị contac
 2730c bị contac
				máy có rớt nước khong bạn bạn nên chạy lại phần mềm xem đả nếu rớt nước hay bị ic nguồn lắm
				đây là log của nó,chạy bằng MX key,anh em xem giúp với
Version from phone: 09.41
Version from file: 09.41
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35797803187357_BA CK.rpl).
Processing file: rm578__09.41.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 21.63 MB
Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101023000
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 14000117B5178C5645982C46B069F6FA0F42643D
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
TransmissionMode: 16Bit
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1
TransmissionMode: DDR&TX2
Erase size: 23.25 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00040000-000BFFFF]
CMT NOR area [000C0000-0013FFFF]
CMT NOR area [00140000-0155FFFF]
CMT NOR area [01560000-0175FFFF]
erased in 2 min 7.828 s
Flash programming ...
CMT PAPUBKEYS: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 (RAP Certificate 215 v1) written.
Programming completed in 3 min 30.875 s
Processing file: rm578__09.41.ppm_mr as PPM
[BB5,BB5 ALGORITHM] size: 6.50 MB
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 8.62 MB
CMT NOR area [01760000-01FFFFFF]
erased in 38.687 s
Programming completed in 1 min 2.266 s
Processing file: rm578__09.41.image_mr_black as CNT
[BB5,BB5 ALGORITHM] page size: 128 K size: 16.39 MB
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 31.75 MB
CMT NOR area [02000000-0245FFFF]
CMT NOR area [02460000-03FBFFFF]
erased in 3 min 12.219 s
Converting UCP blocks to 128 K.
Programming completed in 2 min 34.625 s
Flashing completed in 13 min 21.656 s
Phone Type: RM-578 (Nokia 2730 classic)
SW Version: V 09.41 02-12-09 RM-578 (c) Nokia
Imei plain: 35797803187357-9
Product Code: 0585313
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 357978031873579
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 13 min 51.906 s
				chạy không đúng version của nó rồi, kiếm ver củ đập vào thôi
Next Level 99,9
				SIMLOCK_TEST passed
cái này là gì hả bạn. xem lại nhé. tốt nhất là nên backup lại 1 309 120 và rpl full, sau đólàm cho đỡ sợ. hihi nhưng bây giờ bắc có thể sx4 và write pm full có khi ok.
				cho pm edit vào ok ma
				lỗi đây này cụ.SECURITY_TEST failed!
chạy cho nó cái pm nhé
Chỉ có bia mới hiểu, Bụng mênh mông nhường nào Chỉ có bụng mới biết , Bia đi đâu về đâu
				em update SpLock bị lỗi này
Counter: 0/3, 0/10
Product: V 09.41 02-12-09 RM-578 (c) Nokia
Using cached productData[14000117B5178C5645982C46B069F6FA0F42643D] ...
Calculating SIMLOCK using security server ...
[UnauthorizedFault] Card [C0817F4C] is not assigned (case id=0xCC01)
Reading Simlock info ...
Counter: 0/3, 0/10
[UnauthorizedFault] Card [C0817F4C] is not assigned (case id=0xCC01) là lỗi gì nhỉ
