Mình nhận một chú 1202(2293) bị contact service mình chạy lại báo Ok , chọn NORMAL thì vẫn lên báo lắp sim vào nhưng lắp pin vào hay kẹp nguồn thì lại báo contact service. anh em nào biết bệnh này chỉ mình với TK nhiều.
Log của nó
Getting MCU ID
MCU ID: 0x2293
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 04.03
29-06-09
RH-112
(c) Nokia
HW version:
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_09w22_U
LCD version: WIN:SERI:8a
NT7542
PPM version: V 04.03
29-06-09
RH-112
(c) Nokia
MR
ADSP SW version: V 04.03\n29-06-09\nRH-112\n(c) NMP\nmr
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 351960036034577
IMEI spare to net: 3A 15 69 00 63 30 54 07
IMEI SV to net: 33 15 69 00 63 30 54 17 F9
Master Code: 2077017172
Phone type: RH-112, Software version: 04.03, Language Pack: MR
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
Setting local mode...
Reading product code...
Product Code:
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-112\
No ini files found...
Done!
