Format FFS - resets all settings (including user code) to default value. Similar to "Master Reset" /"Master Clear" function for P2K models.
Connect* powered OFF phone to PC COM port.
Launch SmartMoto.
Select "Computer COM ports" in Phone connection window.
Log to "Compal" tab.
Select an appropriate COM port in SmartMoto.
Press "Format FFS" button.
Press "Power ON" button on the phone, as soon as SmartMoto indicates an appropriate message.
SmartMoto resets settings to default value.
* Compal models require to be connected to PC COM port via original COM data cable or using any COM port emulator.
Cho em hỏi : Em dùng chức năng Format FFS để Format cho Moto C261. Vậy dùng cable loại nào vậy, nếu phải chế cable thì cách xin hướng dẫn cách chế cable . Thanks
			 Hỏi về Format FFS trong SmartMoto !
