Kết quả 1 tới 3 của 3
    Thành viên tích cực minhkhoa_iphone's Avatar
    Mặc định n72 rớt nước mất nguồn cần giúp
    em chay fw tới dây nbo1 báo lổi hoài là sao vay mấy a.
    Detected PKEY: 9001DDC1
    Card life counter: 37.40%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    Booting phone...
    Error sync the phone...
    Booting phone...
    Unknown field ID!
    Booting phone...
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101012200
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 19000208E16746513BDAEEDACCF500E1675C54A4
    HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
    ROM ID: F28A211FCEA7B19D
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
    Loader version: 01.15.00 -> Revision: 0000
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 00330001 <=> SPANSION -> Type not in database
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 01.21.01 -> Revision: 0000
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05wk07v48.1
    28-08-07
    RM-180
    (c) Nokia.
    HW version: 7001
    PCI version:
    RFIC version:  150a160f
    DSP version: rolf_espresso_05wk07v29p1
    Retu version: 32
    Tahvo version: 53
    Production serial number: CFJ423693
    Product code: 0531541
    Module code:
    Basic production code: 0530940
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 353089022295030
    IMEI spare to net: 3A 35 80 09 22 92 05 03
    IMEI SV to net: 33 35 80 09 22 92 05 03 F8
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini
    Setting local mode...
    Reading product code...
    Product Code: 0531541
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\
    Checking path: \Products\RM-180\
    No ini files found...
    Done!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50819401.C0
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50819401.V15
    Languages in ppm: English,Filipino,Indonisia B,Malasia B
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Reading CMT NPC certificate...
    Reading CMT VARIANT certificate...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35308902229503_CRT_backup _1122219.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\353089022295030_CRT_backu p_1123219.pm
    Done!
    Backup LCK OK!
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Sending CNF Data...
    APE blocks present in flash file but no APE mcu detected in phone. Aborting!
    mong mấy anh xem dùm,e dã câu ape theo hình mà vẩn ko dược
    Thành viên tích cực trantukiet1008's Avatar
    Dec 2009
    Phần APE chưa nhận diện được, coi lại phần APE đi anh
    Thành viên mới duyvuong1325's Avatar
    câu áp APE rồi chạy lại là ok thôi,N72,N70..RỚT nược hay bị mất áp APE lắm.chúc thành công
  1. Trả lời: 10
  2. Trả lời: 5
    Bài viết cuối: 30-01-2013, 14:51
  3. Trả lời: 12
    Bài viết cuối: 30-09-2012, 04:37
  4. Trả lời: 13
  5. Trả lời: 8
    Bài viết cuối: 07-01-2010, 22:14
