    V.I.P viethuy_mobi's Avatar
    Dec 2009
    Mặc định nhờ ae xem giúp log 7610 dùm e với
    tai. sao cái log này của e .e phải INF 3 lần thì mới dc.chay xong thì nó báo thế này
    FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
    FLASH ID2: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    Master Code: 3013414237
    Failed! Aborting! MCUVER
    Reading...
    Phone type: RH-51, Software version: 7.0642.0, Language Pack: not available
    User code: 12345
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini
    Setting local mode...
    Failed! Aborting!
    Done!
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
    Checking path: \Products\RH-51\
    No ini files found...
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\350774602175826_imei_back up_2045279.rpl
    Done!
    Backup imei OK!
    Flashing Done!
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Failed! Aborting!...MCUVER
    Phone Type:
    MCU Flash file: D:\nokia\7610\RH51_52_67_68PE706420.C1
    Phone Type:
    PPM Flash file: D:\nokia\7610\RH51PE706420.06
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\350774602175826_imei_back up_2055279.rpl
    Done!
    Backup imei OK!
    MCU: D:\nokia\7610\RH51_52_67_68PE706420.C1
    Booting phone...
    MCU ID: 0x1081
    BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
    Boot size is 0x10D8
    Boot is ready...
    Flash ID is 0x22F800EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
    Loader size is 0x7F10; Loader chk: ac
    Loader is ready...
    MSID: 844E3003B13C5EB4DC4C7DE908
    MSID decoded: 3E4EBAF70043EE2CA9000000
    FAID: 3DABCBA254EF400D094BD2BF
    Operation took 0 minutes 16 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 00FFFFFF...
    Erasing area: 02000000 - 0287FFFF...
    Erasing area: 02FC0000 - 02FEFFFF...
    Operation took 3 minutes 35 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 3 minutes 7 seconds...
    Restarting MCU...
    PPM: D:\nokia\7610\RH51PE706420.06
    Booting phone...
    MCU ID: 0x1081
    Boot size is 0x10D8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 02A00000 - 02CAFFFF...
    Operation took 0 minutes 23 seconds...
    Writing...
    Operation took 0 minutes 21 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 8 minutes 4 seconds...
    Reading...
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    mang qua hwk xóa rồi flask lại là ok
    Thành viên kỳ cựu madao's Avatar
    anh ah.info 3 lần mới được .vậy anh chọn tab nào.coi chừng nhầm tab đó
    Thành viên chính thức tunglaocai's Avatar
    dòng này info phải nháy nút nguồn chớ
    Thành viên tích cực tuongmobil@_1987's Avatar
    NAM ĐỊNH
    xóa full==>nạp fie chuẩn +wite pm good +unlock là ngon thôi anh ạ
    không tiền đố mi làm nên...........!!!!!!!!!!!
    Thành viên kỳ cựu setot_thoi's Avatar
    Sóc Trăng
    đem qua HWK info ok nhưng coi chừng ko use setting đc nhé bạn .
    MẩnMobile .Y/H : Jimmyphong10
    Dec 2009
    Trích Được post bởi tunglaocai Xem bài viết
    con này e ko bấm nút nguồn cũng van inf bình thường ma .nhưng dù sao cũng cảm on các a.e chi co jap thôi
    Sóc Trăng
    JAF ok lắm đấy bạn . bây giờ thay con nguồn nhé sao đó wirte lại phát nửa là OK
    Dec 2009
    thak a nhe.giờ e thử xem sao
  1. Giúp dùm em Log 7610 với
    By anhtruong in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 18-07-2010, 09:29
  2. cứu dùm em con 7610
    By tandong in forum DCT4 - WD2
    Bài viết cuối: 11-11-2009, 17:21
  3. 7610 corrup card name AE giúp dùm
    By tiengianggsm in forum DCT4 - WD2
    Bài viết cuối: 04-04-2009, 14:47
