30/12/2006Smart-Clip v3.06 - S-Card v1.06 - SmartMoto v2.10We are pleased to introduce new versions of Smart-Clip v3.06, S-Card v1.06 and SmartMoto v2.10.With this release following models are added to the list of supported:V3 with boot version 8.28 (unlock via prepare cycle); Model L6/L7 i-mode models unlock via code calculation (tab I-mode).No Smart-Clip needed, S-Card dongle is required only. We wish happiness to everyone and will see you all in New Year 2007!28/12/2006We are pleased to introduce new version of SmartMoto v2.09.With this release launched "IMEI repair" function for the following models with specified boot versions:Model Boot versionE1 A.02L2 8.D0L6 8.D0L6 8.D5L7 8.D0L7 A.20U6 8.A1V190 8.A0V190 8.D0V19x 8.D5V235 8.E0V360 8.A0V360 8.D0V3i A.30V3r A.30V557 8.B0No TestPoint is required. Just perform the next steps:1. Connect powered handset2. Perform a PREPARE cycle3. Log to IMEI repair section4. Press "IMEI repair fw patch"5. Enter IMEI to be restored6. Press "Restore IMEI"In case of need restoring IMEI again the Firmware Patch is not required. Just perform PREPARE cycle and restore the number.25/12/2006We are pleased to introduce new version of SmartMoto v2.08.With this release added PDS repair option for the following models with specified firmware versions:- V365 fw R4518- V3b fw R37AV3- V400p fw R3622Also, - Fixed a connectivity issue for older phones: V66, Т720, А830, etc…We recommend to use only the latest versions of Smart-Clip, S-Card and SmartMoto.If you wish to receive news on updates immediately, please subscribe to our new SMS notification system. From now on, there is no need to send us a text with request of subscription. Just fill your mobile number into the form and get news about next update via SMS. 21/12/2006 S-Card v1.05, SmartMoto v2.06 & Smart-Clip v3.05.We are pleased to introduce new versions of S-Card v1.05, SmartMoto v2.06 & Smart-Clip v3.05.In this release.First in the world! - C975 model, firmware version 91i, is supported for unlock (unlock patch).- Model C975 boot version 6.36 is added to “Non-TestPoint unlock procedure”.- “Non-TestPoint unlock procedure” modified and simplified. No need to flash the handset at the end of the process. User data will remain in the phone.11/12/2006 S-Card v1.02, SmartMoto v2.03 & Smart-Clip v3.02We are pleased to introduce new versions of S-Card v1.02, SmartMoto v2.03 & Smart-Clip v3.02With this release we announce a new step in unlocking, flashing and repairing technologies.From now on, all procedures for majority of the latest models can be performed without disassembling and making a TestPoint connection.The following models can be served avoiding a TestPoint connection:C390 BL up to 8.26 E1 BL up to A.02 L2 BL up to 8.D0L6 BL up to 8.D0 L7 BL up to 8.D0 L7 BL up to A.20 U6 BL up to 8.A1 V190 BL up to 8.A0 V190 BL up to 8.D0 V235 BL up to 8.E0 V360 BL up to 8.A0 V360 BL up to 8.D0 V3i BL up to A.30 V3r BL up to A.30 Please, be aware of the new unlock procedure:- Connect the handset to PC via Smart-Clip (phone > USB cable > Smart-Clip > LPT cable > PC).- Connect S-Card to PC USB port.- Connect power supply to Smart-Clip and power on the handset.- Launch SmartMoto.- Choose "Smart-Clip USB port" in phone connection window.- Press "Search". The software should perform the following steps: + SmartMoto detects S-Card;+ SmartMoto detects Smart-Clip;+SmartMoto detects the handset and reads all phone information.- Log to bookmark "Prepare".- Select the appropriate model from SmartMoto list. Make sure that phone model and boot version of the phone to be unlocked exactly match the model and boot version stated in the list.- For unlock purposes, please make sure that “Unlock automatically” option is mark.- Press “Prepare” button.- Part of phone firmware gets reflashed. At this time popup window appears at SmartMoto interface. Please follow the instructions provided therein:+ Disconnect cable from the phone;+ Remove and insert phone’s battery;+ Press "Power on" key on the phone;+ Connect cable to the phone.+ The handset should restart in boot mode.If the option “Unlock automatically” was marked – the handset becomes unlocked. If the option was not selected then: - The phone can be unlocked by logging to the bookmark “Unlock”, selecting the appropriate model and simply pressing “Unlock via TestPoint”;- The phone can be repaired by logging to the bookmark “Repair”, selecting an appropriate model and pressing “Repair PDS”;- The phone can be flashed by logging to the bookmark flash and performing a “Flash” procedure.- Log to bookmark “Flash”.- The phone has to be flashed with an appropriate firmware.After flash is completed, disconnect the handset.NOTE Please remember to update Smart-Clip first and perform S-Card update after that only. Smart Clip is a professional device that removes SP/SIM/phone/user lock from Motorola phones and Nemesis Ver 2.0 with new hardware to support new type of SonyEricsson phones. it's Supporting New Hardware SE phones, Supporting All possible CID version and fully upgradable.Supported Phones:Smart-Clip unlocks the following cell phone modelsSENDO cell phones:Sendo snd2xx, Sendo snd3xx (incl. snd360 s360), Sendo snd5xx (incl. snd570 m570), Sendo snd6xx (incl. snd600 p600/s600), Sendo snd8xx Motorola ACER platform cell phones:Motorola C115 (incl. v.1.0.50), Motorola C116, Motorola C117, Motorola C155, Motorola C156, Motorola C157, Motorola E365, Motorola V170, Motorola V171 Smart-Clip unlocks and flashes the following cell phone modelsMOTOROLA cell phonesP2K platform:A630, A830, A835, A845, A920, A925, A1000 , C236, C250, C260, C266, C268, C330, C331, C332, C333, C334, C335, C336, C350, C350L (incl. R312ULS_G_09.10.2CR) , C350V, C353, C355V, C359V, C370, C380, C385, C450, C450L, C550, C650, C651, C975, C980 , E1000, E370, E375, E378i, E380 , E396, E398, E550, E920 , T280, T280i, T720 (incl.T720_G_05_08_81R), T720i, T721, T722i, T725e, V3 (incl.R374_G_0E.40.74R,R374_G_0E.40.96R), V60, V60i, V66, V66i, V70 , V80 (incl. R37_G_0E.03.26R), V150 (incl. R313LT_G_09.20.05R), V151, V180 (incl. R364_G_0B.D1.1CR), V186, V188, V220 (incl. R365_G_0B.D2.0.FR, R364_G_0B.D1.1FR), V226, V300, V303, V330 (R472_xx), V400, V500, V505, V525, V525M, V535, V547 (incl. R472_xx), V545, V550, V551 (incl. R472_xx), V600, V620, V635 (ver R474_G_08.48.6CR), v975 (ver R245_xxx), V980, v1050 Package Contains : 1 x Smart-Clip device 6 x Service cables for Smart Clip 1 x Battery connector for Smart Clip Free 1 year access to download site to keep updated with software and flash files
