    Thành viên tích cực tuananh65's Avatar
    Feb 2008
    Hà nội
    Mặc định xin giúp đỡ gấp log 1202 bằng MXkey
    em nhận em nó đã chết nguồn kẹp dong hơi nhich 1 lát rùi trả về đưa vào flash bằng MXkey thì mục CNT chay gần hết báo lỗi rùi chạy tiếp. chạy bằng HWK thì ok nhưng đưa sang MXkey UNLock thì không info được. xin ace giúp đỡ.thanks all
    Đây là log em nó.
    Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
    ASIC ID: 0x2293 [UPPCosto ver: 2.0]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
    Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
    UEM ID: 001963E8A3BDA66
    ASIC type: 11
    UEM Imei: 35830503435355
    Processing file: rh112_004.030 as MCU
    [DCT4,DCT4 ALGORITHM] size: 2.29 MB
    Supported Ids: 2293
    UEM ID: 001963E8:2984DA60
    Area [01000000-0100FFFF] erased in 0.375 s
    Area [01010000-013AFFFF] erased in 21.422 s
    Area [013B0000-013EFFFF] erased in 1.594 s
    Area [017C0000-017EFFFF] erased in 0.140 s
    Area [01FC0000-01FEFFFF] erased in 0.109 s
    Flash programming ...
    Programming completed in 17.547 s
    File Processed in 50.531 s
    Processing file: rh1120_nai04.03mr as CNT
    [DCT4,DCT4 ALGORITHM] size: 110.54 KB
    Supported Ids: 2293
    Area [01380000-013AFFFF] erased in 1.188 s
    Programming completed in 0.922 s
    Content extract fail, continue anyway ...
    File Processed in 1 min 51.610 s
    Processing file: rh112_004.03mr as PPM
    [DCT4,DCT4 ALGORITHM] size: 1.15 MB
    Supported Ids: 2293
    Area [01240000-0124FFFF] erased in 0.375 s
    Area [01250000-0137FFFF] erased in 7.109 s
    Programming completed in 8.813 s
    File Processed in 27.906 s
    Flashing completed in 4 min 3.500 s
    Phone not responding !
    Total time to process is 4 min 36.812 s
    V.I.P ThanhHai_GSM's Avatar
    check lại cpu xong chạy lại đi bạn
  3. ( ThanhHai_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tuananh65 (08-10-2010)
    Feb 2008
    Hà nội
    mình cũng nghĩ như vậy nhưng chưa bao giờ gặp kiểu như thế này nên cần ý kiến ace giúp đỡ.
    Thành viên tích cực trantukiet1008's Avatar
    Dec 2009
    Lỗi ở chổ này, anh kiếm file chuẩn đập vào là ok thôi
    Feb 2008
    Hà nội
    mình làm ok rùi không bít cha nào trước làm bỏ đi 1 con L nhìn qua cái main khác thấy thiếu úp sọt thế là lên luôn khà khà. bác nào mà cao tay quá ta.
  1. cách check 1202 1280 bằng mxkey nè
    By dainghia132 in forum DCT4 - WD2
    Bài viết cuối: 26-03-2011, 22:26
  2. xin giúp 1202 chạy bằng mxkey
    By mobile_minhhieu in forum DCT4 - WD2
    Bài viết cuối: 11-12-2010, 10:41
  3. MXKEY - UFC3GS flashing X-GOLD/Infineon devices(1202,1616,1800, etc)
    By hungphongmobile™ in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 25-06-2010, 10:20
  4. MXKEY - First in the world REAL unlock for Nokia 1202, 1661, 1662, 5030
    By TUYHOAGSM™ in forum MX-KEY (by Alim Hape)
    Trả lời: 19
    Bài viết cuối: 12-04-2010, 23:36
  5. video unllock 1202 mxkey
    By họcsinh in forum MX-KEY (by Alim Hape)
    Trả lời: 43
    Bài viết cuối: 16-12-2009, 07:44
