Kết quả 1 tới 3 của 3
    Vi phạm nội quy tuyetnhi_2007's Avatar
    Mặc định file N70 music cần giúp gấp
    huynh nào có file N70 music cho em xin với em em cần gấp thank All
    Thành viên tích cực traibn_pc23's Avatar
    Bắc Ninh
    supost co mà bạn.
    HT Mobile !!!!!!!!!!
    Thank All plash ok rồi
    Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
    Reading phone`s ID ...
    SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
    ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
    ROM ID: F28A211FCEA7B19D
    productData saved.
    Restarting phone ...
    APE Data :
    SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
    ASIC MODE ID: 00
    PUBLIC ID: E899D2E1F62189AF8735A9030906C03B818F2D96
    ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
    ROM ID: AB5E4ADB27A06946
    RAP Data :
    EM0 ID: 00000232
    EM1 ID: 00000352
    PUBLIC ID: 11F00118E43854519061CBF2D0E2D3AB9FC127B3
    ASIC MODE ID: 00
    SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
    Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
    FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,RAP
    TransmissionMode: 16Bit
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
    TransmissionMode: DDR&TX2
    SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
    Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
    FlashID0: 0098 0036 - 00A5 00C0 [Toshiba 512 DDP NAND,512 Mbits] type: NAND,APE
    ALG [35]: OMAP1610 GBBM-1.8.1 ALG
    ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000
    Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908
    APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
    Reading RAP NPC (0x168 bytes).
    Reading RAP VARIANT (0x4F0 bytes).
    Reading RAP CCC (0x0 bytes).
    Reading RAP HWC (0x0 bytes).
    Reading APE NPC (0x0 bytes).
    Reading APE VARIANT (0x0 bytes).
    Reading APE CCC (0x0 bytes).
    Reading APE HWC (0x0 bytes).
    Flash Imei: 35186301181845
    NPC_DATA saved OK
    VARIANT_DATA saved OK
    SUPERDONGLE_KEY_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35186301181845_BA CK.rpl"
    Processing file: RM84_50705301.V32 as PPM
    [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 10.27 MB
    Supported RAP Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200
    APE Data :
    ASIC MODE ID: 00
    RAP Data :
    EM0 ID: 00000232
    EM1 ID: 00000352
    ASIC MODE ID: 00
    Partitioning ...OK
    Erase size: 35.94 MB
    APE NAND area [01AE0000-02AFFFFF] erased in 1.360 s
    APE NAND area [02B00000-03ECFFFF] erased in 1.718 s
    Flash programming ...
    Programming completed in 1 min 38.172 s
    Flashing completed in 3 min 30.796 s
    Phone Type: RM-84 (Nokia N70)
    SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia.
    Imei plain: 35186301181845-3
    Product Code: 0534652
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    Imei net: 351863011818453
    Version: SIMLOCK SERVER VERSION 58
    Provider: Nokia Test, Country: Finland
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    Total time to process is 3 min 41.140 s
  1. Xin File Flash N70 Music
    By PhùngMobile in forum BB5
    Bài viết cuối: 10-02-2012, 10:45
  2. xin file N73 music v4.0839.42.3.1
    By dtddmatai in forum BB5
    Bài viết cuối: 11-05-2011, 20:30
  3. xin file n70 music
    By dinhtrongbd in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 09-03-2010, 18:10
  4. xin file flash N70 music
    By HOCSUA2002 in forum BB5
    Bài viết cuối: 20-09-2009, 15:20
  5. phân biệt file N70 thường và music
    By huynhkiet in forum BB5
    Bài viết cuối: 14-12-2007, 14:37
