Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00D9CAC2A3BDA66
ASIC type: 11
UEM Imei: 35828003182275
Phone Type: RH-112
SW Version: V 04.03 29-06-09 RH-112 (c) Nokia
Imei plain: 35828003182275-8
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MR
Language Pack:
- not available.
Imei net: 35828003182275
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Invalid UEM Data, No RPL backup will be made for this phone.
mong ace giúp đỡ em gửi file bằng MXkey thì báo lỗi như thế này
ASIC type: 11
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35828003182275.RP L"
Programming FLASH Imei ...
FLASH programmed successfully.
warning: For UEM write, VBAT needs to be atleast: 5.2V
Programming UEM Imei (OTP) ...failed
Phone Type: RH-112
Ppm Id: MR
Language Pack:
- not available.
Counter: 0/3, 0/10
mong ace giúp đỡ thanks all
			 ace xem giùm log 1202
