    Thành viên chính thức trungtramthan's Avatar
    Mặc định 1208 mất loa trong cần giúp gấp
    mình mới nhận một con 1208 bị contac.mình thay nguồn khác vao thì bị mất loa trong.minh chay lai phần mềm thì báo như sau:
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh 105\rh105_05.710
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh 105\rh105_05.71mr
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh 105\rh1050_nai5.71mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh 105\rh105_05.710
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: d9
    Loader is ready...
    MSID: 84041624171A7E91C73C4249CC
    MSID decoded: 3E4EBAE9001D8804A8000000
    FAID: 13AB9A743C9ECD94AE9BCBE3
    Erasing...
    Found 5 interval(s) to erase
    Operation took 0 minutes 43 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 20 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh 105\rh105_05.71mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rh 105\rh1050_nai5.71mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 40 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    FAILED
    nhưng vẫn lên nguồn bình thường ai biết chỉ dùm em với thanks mọi người
    V.I.P ThanhHai_GSM's Avatar
    thay ic nguồn xong nạp imei ,pm, unlock cái đi bạn
    Dec 2009
    GIALAI
    anh kiểm tra mấy con tụ và cuộn dây chỗ đầu cục rung xem. thay nguồn phải nạp rpl +pm và unlock nữa
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Thành viên mới dienloc20009's Avatar
    Oct 2010
    mất loa trong nhưng có loa ngoài hầu hết là do cái chân xạc nó bị chập chân xạc chỗ cắm tai nghe ấy minh gặp nhiều rồi chưa cắc là bị phần mềm đâu
    Thành viên tích cực VƯƠNGANH-HẢI PHÒNG's Avatar
    Sep 2010
    phoenix free
    (mất loa trong nhưng có loa ngoài hầu hết là do cái chân xạc nó bị chập chân xạc chỗ cắm tai nghe ấy minh gặp nhiều rồi chưa cắc là bị phần mềm đâu )
    chủ thớt ??
    Ở ẨN
    V.I.P Lão_Đại's Avatar
    hải phòng
    Bạn lên xử lý ngon phần mềm đã , máy của bạn bây giờ còn nghe gọi bình thường ko , còn IMEI ko ?
    còn loa thì bạn làm lại con IC tiếng là ok thôi (nói thêm tí nữa , nếu thử máy gọi đến có chuông thì bạn phải sử lí cái chân tai nghe nhé )
    Thành viên tích cực dr556's Avatar
    thay chổ nao thỉ giờ anh lảm lại chỗ đó thui anh.tim nguồn tốt thay lai xem sao anh.
  1. 1208 loa trong nghe nhỏ? xin giúp???
    By ut277567 in forum DCT4 - WD2
    Bài viết cuối: 15-06-2011, 18:06
  2. 1208 loa trong rè
    By chemgio_90 in forum DCT4 - WD2
    Trả lời: 19
    Bài viết cuối: 25-02-2011, 11:57
  3. 1208 mất loa trong xin giúp
    By hoangtu88love in forum DCT4 - WD2
    Bài viết cuối: 07-07-2010, 14:23
  4. 1208 loa trong rè
    By minhquan0989908397 in forum DCT4 - WD2
    Bài viết cuối: 29-11-2009, 16:43
  5. Giúp em với 1208 không có loa trong
    By dosat in forum DCT4 - WD2
    Bài viết cuối: 02-10-2008, 19:26
