Kết quả 1 tới 10 của 15
    Thành viên tích cực ngocminhhungyen's Avatar
    jhhj
    Post 3110c xin giúp
    các ace xem hộ mik cái log này mới
    Version from phone: 07.21
    Version from file: 07.21
    Using device: POTATO BOX, FW ver: 01.B4
    Library version: 1.0.0.8986(19-10-2010), 1.0.0.14852(19-10-2010)
    Invalid imei plain, RPL backup skipped.
    Processing MCU file: rm237__07.21.mcusw
    [BB5,BB5 ALGORITHM] size: 14.48 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 2610020AEAB77B560F66BB137FCE2E66E63B51CE
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT NOR area [00000000-000006BF]
    CMT NOR area [000006C0-0001FFFF]
    CMT NOR area [00020000-0007FFFF]
    CMT NOR area [00080000-000DFFFF]
    CMT NOR area [00100000-001FFFFF]
    CMT NOR area [00200000-0031FFFF]
    CMT NOR area [00320000-0105FFFF]
    CMT NOR area [01060000-01067FFF]
    CMT NOR area [01068000-0107FFFF]
    erased in 1 min 32.875 s
    Flash programming ...
    CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written.
    Programming completed in 2 min 37.703 s
    Processing PPM file: rm237__07.21.ppm_v
    [BB5,BB5 ALGORITHM] size: 4.35 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 4.62 MB
    CMT NOR area [01080000-0151FFFF]
    erased in 27.250 s
    Programming completed in 47.937 s
    Processing CNT file: rm237__07.21.image_v
    [BB5,BB5 ALGORITHM] page size: 64 K size: 5.01 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 10.75 MB
    CMT NOR area [01520000-01FDFFFF]
    erased in 1 min 23.328 s
    Converting UCP blocks to 128 K.
    Programming completed in 55.313 s
    Total time for flashing process(boot+erase+write) was 7 min 58.969 s
    Flashing completed in 8 min 1.547 s
    Phone Type: RM-237 (Nokia 3110c)
    SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
    Imei plain: 12345610654321-?
    Product Code: 0552816
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    SUPERDONGLE_KEY invalid!
    - WD timer enabled, phone will reboot itself after 3 min.
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Imei plain is invalid !!!
    Imei net: 12345610654321?
    Version: SIMLOCK SERVER VERSION 63
    Counter: 0/3, 0/10
    CONFIG_DATA: FFFFFFFFFFFFFFFF
    PROFILE_BITS: FFFFFFFFFFFFFFFF
    BLOCK 1: 1=CORRUPTED
    Repair - Unlock - Nạp tiếng việt - Chuyển hệ cho tất cả các loại ĐTDĐ
    V.I.P ThanhHai_GSM's Avatar
    Counter: 0/3, 0/10
    có backup đc gì không bạn nếu đc 308 hay rpl thì nạp vào còn có huy vọng
    không thì thay nguyên cặp cpu & flash
    jhhj
    k cò cách nào sao?mik k backup đc
    ĐÔ LƯƠNG _ NGHỆ AN
    Trích Được post bởi ngocminhhungyen Xem bài viết
    không backup thì kiếm cặp khác thay đi thôi
    Thành viên chính thức huyhoangnokia's Avatar
    Ko backup đc thì chỉ còn nước thay nguyên cặp UPP+flash thui anh.
    xin chia buồn.
    Tân kỳ _ Nghệ An
    Yahoo : huyhoangnokia
    Moderator DuyQNgãi's Avatar
    Quảng Ngãi City
    anh kiểm tra khi anh chạy còn 2 file backup không anh , nếu không thì thay cặp Raps thôi anh
    banh 308 rồi
    Thành viên tích cực tuananh65's Avatar
    Feb 2008
    Hà nội
    nếu backup được RPL thì còn hi vọng đó bạn.
    V.I.P DinhKha™'s Avatar
    Kiên Giang
    Tìm 1 cặp khác thay vào.
    ffffffffff rùi bạn ơi
    CHIÊU ANH ĐT:0933878095
    jhhj
    thanks ace chắc mik phải kiếm cặp khác rồi
  1. 3110c cần giúp đỡ
    By Apple179 in forum BB5
    Bài viết cuối: 06-11-2010, 11:40
  2. Log 3110c cần giúp
    Bài viết cuối: 06-11-2010, 10:19
  3. 3110C cần anh em giúp đỡ
    By BUIVANCHUNG in forum BB5
    Bài viết cuối: 09-10-2009, 21:24
  4. 3110c cấn giúp đỡ
    By ductungsl in forum BB5
    Trả lời: 16
    Bài viết cuối: 06-10-2009, 20:56
