Kết quả 1 tới 3 của 3
    Thành viên chính thức pduyen_mobile's Avatar
    Oct 2010
    tố nử vương quốc
    Mặc định mấy anh xem dùm log rh122_1661_2
    JAF version 1.98.62
    Detected PKEY: 90009699
    Card life counter: 99.99%
    Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
    JAF DCT4/BB5 PRODUCT DIR: E:\NOKIA FIRMWARE\Products\
    USB Cable Driver version: 7.1.23.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: E:\NOKIA FIRMWARE\Products\rh-122\rh122_005.010
    Phone Type:
    PPM Flash file: E:\NOKIA FIRMWARE\Products\rh-122\rh122_005.01mr
    Phone Type:
    CNT Flash file: E:\NOKIA FIRMWARE\Products\rh-122\rh1220_nai05.01mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: E:\NOKIA FIRMWARE\Products\rh-122\rh122_005.010
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    FLASH ID0: 225400EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
    Flash ID is 0x5422EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x7528; Loader chk: 1c
    Loader is ready...
    MSID: 847602E6B24C5937C67908DD45
    MSID decoded: 3E4EBAE900D000FCAA000000
    FAID: C31646C61C7E049B4702F664
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 01010000 - 0179FFFF...
    Erasing area: 017A0000 - 017EFFFF...
    Erasing area: 01F00000 - 01FDFFFF...
    Operation took 0 minutes 57 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 13 seconds...
    Restarting MCU...
    PPM: E:\NOKIA FIRMWARE\Products\rh-122\rh122_005.01mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01250000 - 0125FFFF...
    Erasing area: 01260000 - 0174FFFF...
    Operation took 0 minutes 35 seconds...
    Writing...
    Operation took 0 minutes 15 seconds...
    Restarting MCU...
    CNT: E:\NOKIA FIRMWARE\Products\rh-122\rh1220_nai05.01mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 849FE9078648E52E4B3A4016B0
    MSID decoded: 3E4EBAE900D000FCA8000000
    FAID: 1BD05CA0982F32FAE7E05A22
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01750000 - 0178FFFF...
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 3 minutes 14 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    lúc nhận máy mất nguồn em thay cpu xong nó thế này
    service centre"mobile unlock nạp tv ,nokia ,sony ,lg ,anycall samsung, sky, korea
    BF chạy cò
    V.I.P ThanhHai_GSM's Avatar
    bạn chuỷen sang hwk chạy lại xem nó báo sao bạn
  3. ( ThanhHai_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    pduyen_mobile (25-10-2010)
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    kiểm tra bsi hoặc có thể chạy bằng cáp USB, lỗi ko đồng bộ được. bạn thử xóa full nạp lại flash và pm full + unlock bằng mx key xem thế nào
  5. ( nhanvnn ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. Trả lời: 5
    Bài viết cuối: 08-05-2014, 10:25
  2. anh em check dùm con ip 5 dùm nhà mạng nào
    By NHẬTMINH_GSM in forum iPHONE 5 - 5s
    Bài viết cuối: 26-10-2013, 09:55
  3. Anh em xem dùm con 6085 bus check bị lỗi gì dùm em với
    By hunglangtu_qb in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-08-2013, 09:11
  4. Xin a/e check dùm con 3gs và tư vấn dùm e
    By keylove779 in forum iPHONE 3Gs
    Bài viết cuối: 03-08-2013, 11:47
  5. Mấy anh xem dùm log n-gate qd dùm
    By minhkhoa_iphone in forum DCT4 - WD2
    Bài viết cuối: 14-12-2009, 14:42
