Instructions for RIFF Box owners with damaged/not working hardware:
Here is short list of possible problems which can not be fixed without sending box for repair, or replacing at Your reseller :
* I/O Voltage problems :
If this error appears even without target connected, box have malfunctioning hardware parts, and need to be repaired.Set I/O Voltage to 1.80V failed. Real reading is 3.91V
* Box constantly in bootcore mode:
If even after successful firmware upgrade, box remains in bootcore mode, You need to send it back for repair.
* Box unable to detect target :
If You have this error with 100% tested phone, and even after reworking 20pin ribbon cable, You need to send box for repair.Connecting to the dead body...FAILED
None was found.
__________________________________________________
! ! ! IMPORTANT ! ! ! !
Before contacting factory, You still need to finish diagnostic with tech support, so if You think that You have HW problem with box, first contact us via ICQ :
ICQ#: 299-912-089
We DO NOT work on sundays!
			 Riff box hardware repair and replacement
