Kết quả 1 tới 10 của 11
    Thành viên chính thức thanh900's Avatar
    Apr 2008
    Mặc định giúp dùm cây nokia 2610b
    máy nokia 2610d máy từ noài nước đem về. mong anh em giúp dùm cách mỡ mạng dùm.anh em làm qua rồi xin chĩ giúp.
    Moderator nguyen's Avatar
    Oct 2006
    BẠC LIÊU
    1-Máy rm hay rh mấy?
    2-Imei đầu 01 hay 35?
    cho anh em biết , anh em chỉ cho.
    HẠNH NGUYÊN MOBILE.
  3. ( nguyen ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    thanh900 (25-10-2010)
    Apr 2008
    máy rh 78 imei 01175000694883
    MCU ID: 0x3168
    FLASH ID0: 88040020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 07.04a
    26-08-08
    RH-87
    (c) Nokia.
    HW version: 6100
    PCI version:
    UEM version: 1328
    UPP version: 12648
    RFIC version: 0500
    DSP version: P05w45.v49
    LCD version: ELBE
    PPM version: V 07.04a
    26-08-08
    RH87
    (c) Nokia.
    MCR
    Content Pack version: Content: att
    22-09-08
    RH-87
    (c) Nokia.
    Production serial number: REM271740
    Product code: 0584433
    Module code: 0203968
    Basic production code: 0567073
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 011750006948837
    IMEI spare to net: 0A 11 57 00 60 49 88 03
    IMEI SV to net: 03 11 57 00 60 49 88 63 F1
    Master Code: 7411260500
    Phone type: RH-87, Software version: 07.04a, Language Pack: MCR
    User code: 12345
    Block 1:
    Lock 1: CLOSED -> Lock Data: 310150
    Block 2:
    Lock 1: CLOSED -> Lock Data: 310170
    Block 3:
    Lock 1: CLOSED -> Lock Data: 311180
    Block 4:
    Lock 1: CLOSED -> Lock Data: 310410
    Block 5:
    Lock 1: CLOSED -> Lock Data: 310980
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-87.ini
    Setting local mode...
    Reading product code...
    Product Code: 0584433
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-87\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-87\
    No ini files found...
    Done!
    thanks
    Apr 2008
    máy rh87 imei o1175000694883
    MCU ID: 0x3168
    Algo is ready...
    Done!
    Phone Restarted...
    Reading...
    26-08-08
    RH-87
    (c) Nokia.
    HW version: 6100
    PCI version:
    UEM version: 1328
    UPP version: 12648
    RFIC version: 0500
    LCD version: ELBE
    26-08-08
    RH87
    (c) Nokia.
    MCR
    22-09-08
    RH-87
    (c) Nokia.
    Flash code:
    Order number:
    Long production SN:
    ATO:
    Default SN type:
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Done!
    Apr 2008
    anh nguyên oi .em chạy nó báo vậy thôi hà làm lam anh nguyên
    Getting MCU ID
    MCU ID: 0x3168
    Algo is ready...
    Done!
    Phone Restarted...
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__07.10.mcusw
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__07.10.ppm_rcm
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__07.10.image_rcm
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\011750006948837_imei_back up_18202510.rpl
    Done!
    Backup imei OK!
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__07.10.mcusw
    Booting phone...
    MCU ID: 0x3168
    This MCU ID is not supported in chosen flash file...
    Error booting phone...
    TP.Tuy Hòa
    Nạp pm 2610 vô
    mxkey hoặc hwk unlock free nha bạn
    thay lọc thu Z7602
    tiếng việt thì qua MT hay UB gì cũng được nạp 1 file ppm ==> lụm lúa
  8. ( TUYHOAGSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #7
    Apr 2008
    anh oi . có jaf được không anh
    1 file ppm rh gì vậy anh . em không hiễu
    xin giúp
  10. #8
    TP.Tuy Hòa
    NO, nếu được với điều kiện bạn phải thay UPP
    mà giá UPP new bằng với VIBRA-CLIP
    chứ JAF chưa support unlock ID 3168
    hoặc bạn tham khảo thêm cái này sẽ unlock mau hơn
    http://saigonmobile.vn/forum/gioi-th...ip-market.html
  11. ( TUYHOAGSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  12. #9
    Oct 2006
    BẠC LIÊU
    Nạp 3 file này here
    Nạp file pm này here
    Mxkey unlock. Thay lọc thu phát, lụm gạo.
    HẠNH NGUYÊN MOBILE.
  13. ( nguyen ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  14. #10
    TP.Tuy Hòa
    Nạp 3 file này
    Cái quan trọng ở đây là chủ thớt có mõi JAF sao nạp đây
  15. ( TUYHOAGSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. xin file nokia 2610b RH-87
    By do dinh hoang in forum DCT4 - WD2
    Bài viết cuối: 08-03-2014, 14:38
  2. Trả lời: 8
    Bài viết cuối: 28-04-2010, 14:13
  3. NOKIA 2610b
    By trandinhnong in forum CÁC LOẠI ĐIỆN THOẠI KHÁC
    Bài viết cuối: 19-07-2009, 21:02
  4. Nokia 2610b cần giúp đỡ?
    By ducmobile84 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 09-07-2009, 08:20
  5. Nokia 2610b cần giúp
    By nguyenhuy in forum DCT4 - WD2
    Bài viết cuối: 01-05-2009, 14:35
