máy khách rớt đất mất nguồn mình đã gia cố tất cả các ic vẫn k lên đc nên mình thay cho em nó con u khác chạy lại thì cấp nguồn giao động có nguồn nhưng k lên nguồn đc .mình cũng thay thử mấy cái màn hình vẫn not ok nhờ ae tư vấn giúp , log của em nó đây 0x2293
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
No ini files found...
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RH-112\rh112_004.030
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RH-112\rh112_004.03mr
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\products\RH-112\rh1120_nai04.03mr
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\products\RH-112\rh112_004.030
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 8456352DBAFD6ECE7DEABBE486
MSID decoded: 3E4EBAE900031607A9000000
FAID: 57893641475FBD368F6CC1BD
Operation took 0 minutes 13 seconds...
Erasing...
Found 5 interval(s) to erase
Operation took 1 minutes 3 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\products\RH-112\rh112_004.03mr
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84DB6DC8C48BF7DD829782DBF8
MSID decoded: 3E4EBAE900031607A8000000
FAID: DD6D7487799E5E1CF6F6120D
Erasing PPM...
Found 2 interval(s) to erase
Operation took 0 minutes 20 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\products\RH-112\rh1120_nai04.03mr
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 53 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-112, Software version: 04.03
IMEI: 355244036291255
Product Code: 0562324
Resetting PPC...
Done!
Unlocking...
ASIC: b
SW version: 04.03
Unlock not supported!
Failed! Aborting!
Setting test mode...
Setting FULL FACTORY...
Done!
